Docker: nvcr.io/nvidia/tensorflow:19.08-py3
Linux ubuntu 16.04
GPU: V100
Nvidia driver 418.67
CUDA 10.1
CUDNN version
Python 3
Tensorflow 1.14
TensorRT 6.0.1.5
I have a uffparser issue when runing self-converted ncf model.
I created a .pb model for ncf using tensorflow docker, and converted it to uff files successfully. Below is the log info.
2019-12-09 09:01:28.125008: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudart.so.10.1
WARNING: Logging before flag parsing goes to stderr.
W1209 09:01:29.586434 140589483484992 deprecation_wrapper.py:119] From /usr/local/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py:18: The name tf.GraphDef is deprecated. Please use tf.compat.v1.GraphDef instead.
Loading ncf_20m.pb
W1209 09:01:29.588292 140589483484992 deprecation_wrapper.py:119] From /usr/local/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py:227: The name tf.gfile.GFile is deprecated. Please use tf.io.gfile.GFile instead.
W1209 09:01:30.000069 140589483484992 deprecation_wrapper.py:119] From /usr/lib/python3.6/dist-packages/graphsurgeon/_utils.py:2: The name tf.NodeDef is deprecated. Please use tf.compat.v1.NodeDef instead.
UFF Version 0.6.5
=== Automatically deduced input nodes ===
[name: “user_input”
op: “Placeholder”
attr {
key: “dtype”
value {
type: DT_INT32
attr {
key: “shape”
value {
shape {
dim {
, name: “item_input”
op: “Placeholder”
attr {
key: “dtype”
value {
type: DT_INT32
attr {
key: “shape”
value {
shape {
dim {
=== Automatically deduced output nodes ===
[name: “neumf/output/BiasAdd”
op: “BiasAdd”
input: “neumf/output/MatMul”
input: “neumf/output/bias/read”
attr {
key: “T”
value {
type: DT_FLOAT
attr {
key: “data_format”
value {
s: “NHWC”
Using output node neumf/output/BiasAdd
Converting to UFF graph
DEBUG [/usr/local/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py:96] Marking [‘neumf/output/BiasAdd’] as outputs
No. nodes: 47
UFF Output written to ncf_20m.uff
But when I tried to use sampleMovieLens to run this model, I have the error which saide as below.
&&&& RUNNING TensorRT.sample_movielens # ./bin/sample_movielens
[11/09/2019-09:04:46] [I] Building and running a GPU inference engine for MLP NCF model…
[11/09/2019-09:04:47] [I] Begin parsing model…
[11/09/2019-09:04:48] [E] [TRT] neumf/embedding_lookup: indices input must be Int32
[11/09/2019-09:04:49] [E] [TRT] neumf/embedding_lookup_1: indices input must be Int32
[11/09/2019-09:04:52] [E] [TRT] neumf/embedding_lookup_2: indices input must be Int32
I have already modified the initializeSampleParams function in sampleMovieLens.cpp based on input and output.
params.uffFileName = locateFile(“ncf_20m.uff”, params.dataDirs);
params.embeddingVecSize = 32;
params.topKMovies = 1;
params.numMoviesPerUser = 100;
params.ratingInputFile = locateFile(“movielens_ratings.txt”, params.dataDirs);
params.inputTensorNames.push_back("user_input");
params.inputTensorNames.push_back("item_input");
params.outputTensorNames.push_back("neumf/output/BiasAdd");
Please help me for this problem.
