Description
Trt ouput mismatch with onnx output. Use polygraph run will failed with “Difference exceeds tolerance”.
Onnx file: https://pan.baidu.com/s/1qd3NSrqIU-aJ4ZrHxO97Ag?pwd=43rg 提取码: 43rg
Polygraph cmd:
polygraphy run /tmp/Janus-Pro-7B/vision_encoder_bfp16.onnx --onnxrt --trt \
--save-engine=/tmp/Janus-Pro-7B/vision_encoder_bfp16.trt \
--trt-min-shapes 'input:[1,3,384,384]' \
--trt-opt-shapes 'input:[1,3,384,384]' \
--trt-max-shapes 'input:[8,3,384,384]' \
--input-shapes 'input:[-1,3,384,384]' \
--atol 1e-1 --rtol 1e-1 \
--fail-fast
Failed log:
[I] trt-runner-N0-02/20/25-22:26:11 | Completed 1 iteration(s) in 1723 ms | Average inference time: 1723 ms.
[I] Accuracy Comparison | onnxrt-runner-N0-02/20/25-22:26:11 vs. trt-runner-N0-02/20/25-22:26:11
[I] Comparing Output: 'output' (dtype=float16, shape=(1, 576, 4096)) with 'output' (dtype=float16, shape=(1, 576, 4096))
[I] Tolerance: [abs=0.1, rel=0.1] | Checking elemwise error
[I] onnxrt-runner-N0-02/20/25-22:26:11: output | Stats: mean=-0.035358, std-dev=4.1854, var=17.517, median=-0.0059319, min=-303.75 at (0, 121, 2526), max=102.44 at (0, 121, 411), avg-magnitude=2.5026
[I] ---- Histogram ----
Bin Range | Num Elems | Visualization
(-304 , -263 ) | 2 |
(-263 , -222 ) | 1 |
(-222 , -182 ) | 1 |
(-182 , -141 ) | 1 |
(-141 , -101 ) | 13 |
(-101 , -60 ) | 107 |
(-60 , -19.4) | 5218 |
(-19.4, 21.2 ) | 2350202 | ########################################
(21.2 , 61.8 ) | 3692 |
(61.8 , 102 ) | 59 |
[I] trt-runner-N0-02/20/25-22:26:11: output | Stats: mean=-0.015617, std-dev=1.5098, var=2.2795, median=-0.0024776, min=-94.25 at (0, 121, 2526), max=43.531 at (0, 121, 3649), avg-magnitude=0.99653
(-304 , -263 ) | 0 |
(-263 , -222 ) | 0 |
(-222 , -182 ) | 0 |
(-182 , -141 ) | 0 |
(-141 , -101 ) | 0 |
(-101 , -60 ) | 1 |
(-60 , -19.4) | 79 |
(-19.4, 21.2 ) | 2359190 | ########################################
(21.2 , 61.8 ) | 26 |
(61.8 , 102 ) | 0 |
[I] Error Metrics: output
[I] Minimum Required Tolerance: elemwise error | [abs=251.31] OR [rel=3.9922e+06] (requirements may be lower if both abs/rel tolerances are set)
[I] Absolute Difference | Stats: mean=2.4379, std-dev=3.0746, var=9.453, median=1.4648, min=0 at (0, 0, 3844), max=251.31 at (0, 77, 2526), avg-magnitude=2.4379
(0 , 25.1) | 2355495 | ########################################
(25.1, 50.3) | 3576 |
(50.3, 75.4) | 194 |
(75.4, 101 ) | 21 |
(101 , 126 ) | 4 |
(126 , 151 ) | 1 |
(151 , 176 ) | 1 |
(176 , 201 ) | 1 |
(201 , 226 ) | 2 |
(226 , 251 ) | 1 |
[I] Relative Difference | Stats: mean=28.596, std-dev=3638.5, var=1.3238e+07, median=1.9318, min=0 at (0, 0, 3844), max=3.9922e+06 at (0, 66, 2211), avg-magnitude=28.596
(0 , 3.99e+05) | 2359282 | ########################################
(3.99e+05, 7.98e+05) | 7 |
(7.98e+05, 1.2e+06 ) | 4 |
(1.2e+06 , 1.6e+06 ) | 1 |
(1.6e+06 , 2e+06 ) | 0 |
(2e+06 , 2.4e+06 ) | 1 |
(2.4e+06 , 2.79e+06) | 0 |
(2.79e+06, 3.19e+06) | 0 |
(3.19e+06, 3.59e+06) | 0 |
(3.59e+06, 3.99e+06) | 1 |
[E] FAILED | Output: 'output' | Difference exceeds tolerance (rel=0.1, abs=0.1)
[E] FAILED | Runtime: 24.394s | Command: /usr/local/bin/polygraphy run /tmp/Janus-Pro-7B/vision_encoder_bfp16.onnx --onnxrt --trt --save-engine=/tmp/Janus-Pro-7B/vision_encoder_bfp16.trt --trt-min-shapes input:[1,3,384,384] --trt-opt-shapes input:[1,3,384,384] --trt-max-shapes input:[8,3,384,384] --input-shapes input:[-1,3,384,384] --atol 1e-1 --rtol 1e-1 --fail-fast
Environment
TensorRT Version: 10.7.0
NVIDIA GPU: A10
NVIDIA Driver Version: 550.90.07
CUDA Version: 12.6
CUDNN Version: 9.6.0
Operating System: Ubuntu 24.04.1 LTS \n \l
Python Version (if applicable): 3.12.3
