Description
Polygraphy take an Onnx with three dynamic outputs sizes and create a new folded Onnx with static outputs sizes
Polygraphy version is 0.35.1
Please explain why the folded model outputs sizes are not dynamic?
Environment
TensorRT Version: 8.4.0.6
GPU Type: Quadro RTX 3000
Nvidia Driver Version: R516.01 (r515_95-3) / 31.0.15.1601 (4-24-2022)
CUDA Version: 11.7
CUDNN Version: 8.1.1
Operating System + Version: Windows 10
Python Version (if applicable): 3.6.8
TensorFlow Version (if applicable): NA
PyTorch Version (if applicable): NA
Baremetal or Container (if container which image + tag): Baremetal
Relevant Files
model.onnx (3.6 MB)
Steps To Reproduce
Perform the following command:
python polygraphy surgeon sanitize model.onnx --fold-constants -o model_folded.onnx
I got the following report:
[I] Original Model:
Name: torch-jit-export | Opset: 13
---- 1 Graph Input(s) ----
{input [dtype=float32, shape=(1, 3, 320, 256)]}
---- 3 Graph Output(s) ----
{output [dtype=float32, shape=(‘Divoutput_dim_0’, ‘Divoutput_dim_1’, ‘Divoutput_dim_2’)],
798 [dtype=float32, shape=(‘Gather798_dim_0’, ‘Gather798_dim_1’, ‘Gather798_dim_2’)],
635 [dtype=float32, shape=(6450, 1)]}
---- 56 Initializer(s) ----
---- 560 Node(s) ----
[I] Folding Constants | Pass 1
[W] Module: ‘onnx_graphsurgeon’ version ‘0.3.12’ is installed, but version ‘>=0.3.13’ is recommended.
Consider installing the recommended version or setting POLYGRAPHY_AUTOINSTALL_DEPS=1 in your environment variables to do so automatically.
2022-05-26 15:22:32.6251047 [W:onnxruntime:, unsqueeze_elimination.cc:20 onnxruntime::UnsqueezeElimination::Apply] UnsqueezeElimination cannot remove node Unsqueeze_235
[I] Total Nodes | Original: 560, After Folding: 285 | 275 Nodes Folded
[I] Folding Constants | Pass 2
[I] Total Nodes | Original: 285, After Folding: 261 | 24 Nodes Folded
[I] Folding Constants | Pass 3
[I] Total Nodes | Original: 261, After Folding: 253 | 8 Nodes Folded
[I] Folding Constants | Pass 4
[I] Total Nodes | Original: 253, After Folding: 252 | 1 Nodes Folded
[I] Folding Constants | Pass 5
[I] Total Nodes | Original: 252, After Folding: 252 | 0 Nodes Folded
[I] Saving ONNX model to: model_folded.onnx
[I] New Model:
{output [dtype=float32, shape=(1, 6450, 128)],
798 [dtype=float32, shape=(1, 6450, 2)],
---- 126 Initializer(s) ----
---- 252 Node(s) ----
The generated folded model has tensors outputs which their sizes are static instead of static sizes has the input model has.
