I think everything is correctly installed. I can run build and run the device query example without any problem (after changing the base docker image to r32.4.4). Here is the output:
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "Xavier"
CUDA Driver Version / Runtime Version 10.2 / 10.2
CUDA Capability Major/Minor version number: 7.2
Total amount of global memory: 7772 MBytes (8149057536 bytes)
( 6) Multiprocessors, ( 64) CUDA Cores/MP: 384 CUDA Cores
GPU Max Clock rate: 1109 MHz (1.11 GHz)
Memory Clock rate: 1109 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 524288 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 1 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: Yes
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 0 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 10.2, CUDA Runtime Version = 10.2, NumDevs = 1
Result = PASS
But I still can’t build my container. Here is a minimal example of the dockerfile:
# This includes L4T (with CUDA etc) and PyTorch 1.6
FROM nvcr.io/nvidia/l4t-pytorch:r32.4.4-pth1.6-py3
# Use bash from here
SHELL ["/bin/bash", "-c"]
# Torch2TRT
RUN cd ~ \
&& git clone https://github.com/NVIDIA-AI-IOT/torch2trt \
&& cd torch2trt && python3 setup.py install --plugins
# Trt_pose
RUN pip3 install tqdm cython pycocotools \
&& apt-get install -y python3-matplotlib \
&& cd ~ \
&& git clone https://github.com/NVIDIA-AI-IOT/trt_pose \
&& cd trt_pose && python3 setup.py install
# Start command line on start
CMD ["/bin/bash"]
Which gives the error posted above.
So I’m not sure what is wrong. I have inspected one of the intermediate containers created and it’s true that the file " libcurand.so.10" does not exist. In my host /usr/local/cuda-10.2/targets
there are two folders aarch64-linux
which is the folder that is also visible inside the container, and x86_64-linux
. The x86_64-linux
folder has libcurand.so.10
in the lib folder. The aarch64-linux
folder does not have that file in lib. It only has:
libcudadevrt.a libcudart.so.10.2.89 libcufft_static_nocallback.a libcupti.so libcurand_static.a liblapack_static.a libnppial_static.a libnppidei_static.a libnppim_static.a libnppitc_static.a libnvperf_host.so libnvrtc-builtins.so.10.2
libcudart.so libcudart_static.a libcufftw_static.a libcupti.so.10.2 libcusolver_static.a libmetis_static.a libnppicc_static.a libnppif_static.a libnppist_static.a libnpps_static.a libnvperf_target.so libnvrtc-builtins.so.10.2.89
libcudart.so.10.2 libcufft_static.a libculibos.a libcupti.so.10.2.75 libcusparse_static.a libnppc_static.a libnppicom_static.a libnppig_static.a libnppisu_static.a libnvgraph_static.a libnvrtc-builtins.so stubs
However on my Xavier NX the aarch64-linux/lib
folder does contain the libcurand.so.10
file:
libcudadevrt.a libcufft_static.a libcuinj64.so.10.2.89 libcurand_static.a libcusparse_static.a libnppial.so.10 libnppicom.so.10 libnppif.so.10 libnppim.so.10 libnppisu.so.10 libnpps.so.10 libnvperf_target.so libnvToolsExt.so.1
libcudart.so libcufft_static_nocallback.a libculibos.a libcusolver.so liblapack_static.a libnppial.so.10.2.1.89 libnppicom.so.10.2.1.89 libnppif.so.10.2.1.89 libnppim.so.10.2.1.89 libnppisu.so.10.2.1.89 libnpps.so.10.2.1.89 libnvrtc-builtins.so libnvToolsExt.so.1.0.0
libcudart.so.10.2 libcufftw.so libcupti.so libcusolver.so.10 libmetis_static.a libnppial_static.a libnppicom_static.a libnppif_static.a libnppim_static.a libnppisu_static.a libnpps_static.a libnvrtc-builtins.so.10.2 stubs
libcudart.so.10.2.89 libcufftw.so.10 libcupti.so.10.2 libcusolver.so.10.3.0.89 libnppc.so libnppicc.so libnppidei.so libnppig.so libnppist.so libnppitc.so libnvgraph.so libnvrtc-builtins.so.10.2.89
libcudart_static.a libcufftw.so.10.1.2.89 libcupti.so.10.2.75 libcusolver_static.a libnppc.so.10 libnppicc.so.10 libnppidei.so.10 libnppig.so.10 libnppist.so.10 libnppitc.so.10 libnvgraph.so.10 libnvrtc.so
libcufft.so libcufftw_static.a libcurand.so libcusparse.so libnppc.so.10.2.1.89 libnppicc.so.10.2.1.89 libnppidei.so.10.2.1.89 libnppig.so.10.2.1.89 libnppist.so.10.2.1.89 libnppitc.so.10.2.1.89 libnvgraph.so.10.2.89 libnvrtc.so.10.2
libcufft.so.10 libcuinj64.so libcurand.so.10 libcusparse.so.10 libnppc_static.a libnppicc_static.a libnppidei_static.a libnppig_static.a libnppist_static.a libnppitc_static.a libnvgraph_static.a libnvrtc.so.10.2.89
libcufft.so.10.1.2.89 libcuinj64.so.10.2 libcurand.so.10.1.2.89 libcusparse.so.10.3.1.89 libnppial.so libnppicom.so libnppif.so libnppim.so libnppisu.so libnpps.so libnvperf_host.so libnvToolsExt.so
So why is that? Is there something wrong with my installation on the host x86 system?
