Description
I ran trtexec
with the attached ONNX model file and this command in a Windows Powershell terminal: .\trtexec.exe --onnx=model.onnx --workspace=4000 --verbose | tee trtexec_01.txt
and it crashed without any errors. I’ve also attached the verbose output file trtexec_01.txt
with this post, you can see that the output was stopped abruptly before it finished optimizing and running inference.
Upon looking into the Windows event log, I found an Error entry (screenshot attached) with the below details view. There is also an Information entry with more details (attached as well). I’m able to run this command with the same ONNX model on numerous other Windows machines just fine, so there’s something specific to this machine. Any ideas/suggestions would be appreciated. The detailed system information is included below for reference.
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>100</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2022-06-15T19:30:42.0147880Z" />
<EventRecordID>17129</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>Application</Channel>
<Computer>[Masked]</Computer>
<Security />
</System>
<EventData>
<Data>trtexec.exe</Data>
<Data>0.0.0.0</Data>
<Data>61b804b9</Data>
<Data>unknown</Data>
<Data>00000000</Data>
<Data>c0000005</Data>
<Data>0000000000018c00</Data>
<Data>57f8</Data>
<Data>01d880edc9c64889</Data>
<Data>63b1c581-e439-4eca-8af2-fd38cf36922c</Data>
<Data />
<Data />
</EventData>
</Event>
Environment
TensorRT Version: 8.2.2.1
GPU Type: RTX 3090
Nvidia Driver Version: 512.95
CUDA Version: 11.6
CUDNN Version: 8.4
Operating System + Version: Windows 10 64-bit Enterprise Version 10.0.19042 Build 19042
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Verbose output file:
trtexec_01.txt (2.8 MB)
Event Log Error Entry:
Event Log Information Entry:
ONNX model file:
model.onnx (14.3 MB)
System information file (collected with msinfo32):
msinfo32.log (247.4 KB)
Steps To Reproduce
Just by running the command above.
