Please help, converting 200MB ResNet50-FPN on Jetson Xavier fails with this error.
[TRT] Internal error: plugin node (Unnamed Layer* 341) [PluginV2Ext]requires 383404800 bytes of scratch space, but only 16777216 is available. Try increasing the workspace size with IBuilderConfig::setMaxWorkspaceSize() if using IBuilder::buildEngineWithConfig, or IBuilder::setMaxWorkspaceSize() if using IBuilder::buildCudaEngine.
Could you enable the --verbose
and share the complete output with us?
It seems that the error occurs from a plugin layer.
Is this your custom implementation or a layer from our plugin library?
Sorry for the missing.
Based on the error message, it seems the model is too large for the embedded environment.
You may need a smaller model since XavierNX only has 8GB memory.
