I am currently working on a .cu
project that includes two .cuh
files: one containing structs, definitions, and constants, and the other containing functions. Recently, I started encountering an error related to the name of a constant in the project. Unfortunately, I am unsure about the cause of the error.
I would greatly appreciate it if anyone could provide insight into what might be causing this issue.
Thank you in advance for your help.
Rafael
I defined the constant in a .cuh file:
__constant__ double d_raio = 180;
The other .cuh file holds:
__device__ int rayIntersectsSphere(
double x0, double y0, double z0, // Ray origin
double x1, double y1, double z1, // Ray direction endpoint
Point &intersectionPoint // Output: Intersection point x-coordinate
// double raio2; raio2 = d_raio; // Sphere radius
double cx; double cy; double cz; // Sphere center
cx = dg_bounds[0];cy = dg_bounds[1];cz = dg_bounds[2];
// Calculate ray direction
double dx = x1 - x0; double dy = y1 - y0; double dz = z1 - z0;
// Quadratic coefficients
double a = dx * dx + dy * dy + dz * dz;
double b = 2 * (dx * (x0 - cx) + dy * (y0 - cy) + dz * (z0 - cz));
double c = (cx * cx + cy * cy + cz * cz) + (x0 * x0 + y0 * y0 + z0 * z0) -
2 * (cx * x0 + cy * y0 + cz * z0) - d_raio * d_raio;
// Compute discriminant
double discriminant = b * b - 4 * a * c;
// No intersection
if (discriminant < 0.0) {return 0;}
// Calculate the nearest intersection (smallest t)
double t = (-b - sqrt(discriminant)) / (2 * a);
// The intersection is behind the ray origin
if (t < 0.0) {return 0;}
// Compute the intersection point
intersectionPoint.x = x0 + t * dx; intersectionPoint.y = y0 + t * dy;
intersectionPoint.z = z0 + t * dz; return 1;}
the error is:
CMakeFiles/prismatic.dir/prismatic.cu.o: in function "__nv_cudaEntityRegisterCallback(void**)":
tmpxft_000e0bb6_00000000-7_prismatic.cudafe1.cpp:(.text+0x649): relocation truncated to fit: R_X86_64_PC32 against ".bss"
tmpxft_000e0bb6_00000000-7_prismatic.cudafe1.cpp:(.text+0x676): relocation truncated to fit: R_X86_64_PC32 against ".bss"
tmpxft_000e0bb6_00000000-7_prismatic.cudafe1.cpp:(.text+0x69e): relocation truncated to fit: R_X86_64_PC32 against ".bss"
tmpxft_000e0bb6_00000000-7_prismatic.cudafe1.cpp:(.text+0x6c7): relocation truncated to fit: R_X86_64_PC32 against ".bss"
tmpxft_000e0bb6_00000000-7_prismatic.cudafe1.cpp:(.text+0x6f1): relocation truncated to fit: R_X86_64_PC32 against ".bss"
tmpxft_000e0bb6_00000000-7_prismatic.cudafe1.cpp:(.text+0x71a): relocation truncated to fit: R_X86_64_PC32 against ".bss"
tmpxft_000e0bb6_00000000-7_prismatic.cudafe1.cpp:(.text+0x742): relocation truncated to fit: R_X86_64_PC32 against ".bss"
tmpxft_000e0bb6_00000000-7_prismatic.cudafe1.cpp:(.text+0x76a): relocation truncated to fit: R_X86_64_PC32 against ".bss"
tmpxft_000e0bb6_00000000-7_prismatic.cudafe1.cpp:(.text+0x793): relocation truncated to fit: R_X86_64_PC32 against ".bss"
tmpxft_000e0bb6_00000000-7_prismatic.cudafe1.cpp:(.text+0x7bd): relocation truncated to fit: R_X86_64_PC32 against undefined symbol "d_raio" in section .bss in CMakeFiles/prismatic.dir/prismatic.cu.o
tmpxft_000e0bb6_00000000-7_prismatic.cudafe1.cpp:(.text+0x7e6): relocation overflow adds omitted from output
/usr/lib/gcc/x86_64-linux-gnu/12/../../../x86_64-linux-gnu/libcudadevrt.a(cuda_device_runtime.o): in function "__nv_cudaEntityRegisterCallback(void**)":
cuda_device_runtime.compute_90.cudafe1.cpp:(.text+0x6a1): failed to convert GOTPCREL relocation against "cudartErrorTable"; relink with --no-relax
cuda_device_runtime.compute_90.cudafe1.cpp:(.text+0x71b): failed to convert GOTPCREL relocation against "cudartErrorCnpMap"; relink with --no-relax
cuda_device_runtime.compute_90.cudafe1.cpp:(.text+0x76b): failed to convert GOTPCREL relocation against "__CNPRT_VERSION_NUMBER__"; reconnect with --no-relax
collect2: error: ld returned 1 exit status
make[2]: *** [CMakeFiles/prismatic.dir/build.make:136: prismatic] Error 1
make[1]: *** [CMakeFiles/Makefile2:83: CMakeFiles/prismatic.dir/all] Error 2
make: *** [Makefile:91: all] Error 2
