Try to run Weston JetPack 4.3 - L4T R32.3.1, system halted
Tried to run Weston on Jetson Nano as:
1.Enter these commands to stop the X server:
$ sudo systemctl stop gdm
$ sudo loginctl terminate-seat seat0
$ sudo pkill -9 X
2. Enter these commands to run Weston from the root user:
$ sudo su
$ unset DISPLAY
$ mkdir /tmp/xdg
$ chmod 700 /tmp/xdg
$ export XDG_RUNTIME_DIR=/tmp/xdg
$ weston --idle-time=0 &
System Halted !
Hi Rock2000,
Please reference below steps to start weston:
1. Stop the display manager:
2. For Weston 6.0 use tegra_drm driver
   $ sudo modprobe tegra-udrm modeset=1
3. Unset the DISPLAY environment variable:
   $ unset DISPLAY
4. Create a temporary xdg directory:
   $ mkdir /tmp/xdg
5. Start the Weston compositor:
   $ sudo XDG_RUNTIME_DIR=/tmp/xdg weston --idle-time=0 &
