Hi, everyone,
I am trying to build a small station with nvidia geforce rtx 2080 ti which can be used to perform AI computing related study and practice.
I installed the CUDA driver. However, I have below problems:
- I cannot use “nvidia-smi” to see the GPU info which includes the number of CUDA cores, etc. Below is what I got after running this command.
| NVIDIA-SMI 515.43.04 Driver Version: 515.43.04 CUDA Version: 11.7 |
| | | MIG M. |
| 0 NVIDIA GeForce … On | 00000000:3B:00.0 Off | N/A |
| 29% 32C P8 16W / 250W | 3MiB / 11264MiB | 0% Default |
| | | N/A |
| 1 NVIDIA GeForce … On | 00000000:AF:00.0 Off | N/A |
| 27% 29C P8 13W / 250W | 3MiB / 11264MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
- I tried to run PySpark to read sample data using CUDA cores. However, I do not know whether the PySpark REALLY call CUDA cores or not. I run “nvidia-smi -l” and get same above output.
Any help and advice would be highly appreciated.
