Hi all,
First post, already a call for help :)
I’m trying to use a gtx 580 with Xen 4 VGA Passthrough, the MB is an Asus P7P55 LX with a i7 870, VT-D is enabled in bios and reported as active by Xen.
I’m using Debian Squeeze as Dom0 and DomU OS.
Dom0 is configured with iommu=1 and iommu=verbose parameters and xen-pciback.hide=(01:00.0)(01:00.1) (but I still see them with lspci in dom0, is that normal?)
I configured DomU .cfg VGA passthrough with
gfx_passthru=1
pci=['01:00.0']
and can see the devices as assignable
root@cloud:~/nvidia# xm pci-list-assignable-devices
0000:01:00.0
0000:01:00.1
(0000:01:00.1 refers to the hdmi audio port)
and then assigned to the DomU
root@cloud:~/nvidia# xm pci-list squeeze1
domain bus slot func
0x0000 0x01 0x00 0x0
Everything seems fine, I can see the card in the DomU
root@squeeze1:~# lspci
00:00.0 VGA compatible controller: nVidia Corporation Device 1080 (rev a1)
the module is loaded and the devices exists
root@squeeze1:~# lsmod
Module Size Used by
nvidia 10442361 0
snd_pcm 60551 0
snd_timer 15582 1 snd_pcm
snd 46446 2 snd_pcm,snd_timer
soundcore 4598 1 snd
snd_page_alloc 6249 1 snd_pcm
i2c_core 15712 1 nvidia
evdev 7352 0
pcspkr 1699 0
ext3 106502 1
jbd 37085 1 ext3
mbcache 5050 1 ext3
xen_netfront 16257 0
xen_blkfront 9435 2
root@squeeze1:~# ls -lh /dev/nvidia*
crw-rw-rw- 1 root root 195, 0 Mar 3 16:26 /dev/nvidia0
crw-rw-rw- 1 root root 195, 255 Mar 3 16:26 /dev/nvidiactl
but deviceQuery fails :(
./NVIDIA_GPU_Computing_SDK/C/bin/linux/release/deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
[ 3276.036642] NVRM: failed to register with the ACPI subsystem!
[ 3276.047716] NVRM: RmInitAdapter failed! (0x23:0x2f:646)
[ 3276.047737] NVRM: rm_init_adapter(0) failed
[ 3276.047839] NVRM: failed to unregister from the ACPI subsystem!
cudaGetDeviceCount FAILED CUDA Driver and Runtime version may be mismatched.
I’m using cuda toolkit 3.2.16, sdk_3.2.16 and I tried both dev driver 260.19.26 and 270.29 (is there a difference between “dev” and normal driver?)
The kernel in Dom0 is the 2.6.32-5-xen-amd64 as packaged in Debian, Xen package version is 4.0.1-2.
Any idea?
DomU-dmesg.txt (14.7 KB)
Dom0-xm_dmesg.txt (6.31 KB)
