I am trying to optimize YoloV3 using TensorRT.
I came this post called
Have you Optimized your Deep Learning Model Before Deployment?
https://towardsdatascience.com/have-you-optimized-your-deep-learning-model-before-deployment-cdc3aa7f413d
Used Enabling GPUs in the Container Runtime Ecosystem https://devblogs.nvidia.com/gpu-containers-runtime/ to install nvidia-docker2
Pulled the latest version of the docker image docker pull aminehy/tensorrt-opencv-python3:version-1.3 from https://hub.docker.com/r/aminehy/tensorrt-opencv-python3/tags
Ran this
$sudo docker run -it --rm -v $(pwd):/workspace --runtime=nvidia -w /workspace -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=unix$DISPLAY aminehy/tensorrt-opencv-python3:version-1.3
Got this error
== NVIDIA TensorRT ==
NVIDIA Release 19.05 (build 6392482)
NVIDIA TensorRT 5.1.5 (c) 2016-2019, NVIDIA CORPORATION. All rights reserved.
Container image (c) 2019, NVIDIA CORPORATION. All rights reserved.
https://developer.nvidia.com/tensorrt
To install Python sample dependencies, run /opt/tensorrt/python/python_setup.sh
root@a38b20eeb740:/workspace# cd /opt/tensorrt/python/
root@a38b20eeb740:/opt/tensorrt/python# chmod +x python_setup.sh
root@a38b20eeb740:/opt/tensorrt/python# ./python_setup.sh
Requirement already satisfied: Pillow in /usr/local/lib/python3.5/dist-packages (from -r /opt/tensorrt/samples/sampleSSD/requirements.txt (line 1)) (6.0.0)
WARNING: You are using pip version 19.2.1, however version 19.3.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
Ignoring torch: markers 'python_version == "3.7"' don't match your environment
Setting up graphsurgeon-tf (5.1.5-1+cuda10.1) ...
Setting up uff-converter-tf (5.1.5-1+cuda10.1) ...
File "<string>", line 1, in <module>
File "/usr/lib/python2.7/dist-packages/uff/__init__.py", line 1, in <module>
from uff import converters, model # noqa
File "/usr/lib/python2.7/dist-packages/uff/model/__init__.py", line 1, in <module>
from . import uff_pb2 as uff_pb # noqa
File "/usr/lib/python2.7/dist-packages/uff/model/uff_pb2.py", line 6, in <module>
from google.protobuf.internal import enum_type_wrapper
ImportError: No module named google.protobuf.internal
chmod: cannot access '/bin/convert_to_uff.py': No such file or directory
The post says it is for Jetson device don’t we have a similar method for GTX platform?
Did post a question on here to https://stackoverflow.com/questions/59456090/bin-convert-to-uff-py-no-such-file-or-directory?noredirect=1#59456090
