Hi everyone,
Outcome sought
Drivers that work on the Nano under Ubuntu Linux for the rtl8812au chipset used by the TP-LINK AC600 adapter
I’m using the Jetson Nano with the Ubuntu 18.04 LTS image;
kathyreid@kathyreid-jetson-nano:~$ uname -a
Linux kathyreid-jetson-nano 4.9.140-tegra #1 SMP PREEMPT Thu Jun 25 21:25:44 PDT 2020 aarch64 aarch64 aarch64 GNU/Linux
I need to connect the Jetson Nano to a WPA-PEAP authenticated network on the 5Ghz band. I’ve purchased a TP-LINK AC-600 USB wireless adapter for this purpose, but I cannot get drivers installed on the Nano. I am comfortable hand-editing wpa_supplicant.conf if required, but we haven’t got to that yet.
Diagnostics that show this is likely a driver issue
- output of
lsusbshows the USB Wireless adapter asBus 001 Device 003: ID 2357:011f - Looking this up it uses a Realtek
rtl8812auchipset - No wireless connection information is shown in Network Manager
- attempts to bring up the wireless interface show no device detected
kathyreid@kathyreid-jetson-nano:~$ sudo ifconfig wlan0
wlan0: error fetching interface information: Device not found
kathyreid@kathyreid-jetson-nano:~$ sudo ifconfig wlan0 up
wlan0: ERROR while getting interface flags: No such device
- There are no wifi-ish modules loaded as shown in
lsmod:
kathyreid@kathyreid-jetson-nano:~$ lsmod
Module Size Used by
cfg80211 589351 0
fuse 103841 2
zram 26166 4
overlay 48691 0
bnep 16562 2
btusb 40213 0
btrtl 7318 1 btusb
btbcm 8808 1 btusb
btintel 10771 1 btusb
spidev 13282 0
nvgpu 1579891 33
bluedroid_pm 13912 0
ip_tables 19441 0
x_tables 28951 1 ip_tables
The output from nmcli also confirms no wireless interface is found:
eth0: connected to Wired connection 1
"Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller"
ethernet (r8168), 00:04:4B:E6:83:5C, hw, mtu 1500
ip4 default
inet4 10.21.82.118/23
route4 0.0.0.0/0
route4 10.21.82.0/23
route4 169.254.0.0/16
inet6 fe80::3c91:3795:1d8e:5c66/64
route6 ff00::/8
route6 fe80::/64
route6 fe80::/64
dummy0: unmanaged
"dummy0"
dummy, 7E:BE:DF:67:EF:E9, sw, mtu 1500
lo: unmanaged
"lo"
loopback (unknown), 00:00:00:00:00:00, sw, mtu 65536
So, now I’ve established it’s a driver issue, which drivers have I tried?
Issues with various drivers
There are several rtl8812au drivers available on GitHub, but they are all failing in various ways.
- github . com /jeremyb31/rtl8812au-1.git (link max rule for new users)
FAILED - doesn’t supportaarch64
kathyreid@kathyreid-jetson-nano:~/rtl8812au-1$ cat /var/lib/dkms/rtl8812au/5.3.4/build/make.log | more
DKMS make.log for rtl8812au-5.3.4 for kernel 4.9.140-tegra (aarch64)
Thu 30 Jul 19:49:25 AEST 2020
make ARCH=aarch64 CROSS_COMPILE= -C /lib/modules/4.9.140-tegra/build M=/var/lib/
dkms/rtl8812au/5.3.4/build O="" modules
make[1]: Entering directory '/usr/src/linux-headers-4.9.140-tegra-ubuntu18.04_aa
rch64/kernel-4.9'
Makefile:667: arch/aarch64/Makefile: No such file or directory
make[1]: *** No rule to make target 'arch/aarch64/Makefile'. Stop.
make[1]: Leaving directory '/usr/src/linux-headers-4.9.140-tegra-ubuntu18.04_aar
ch64/kernel-4.9'
Makefile:1711: recipe for target 'modules' failed
make: *** [modules] Error 2
- github . com /aircrack-ng/rtl8812au (link max rule for new users)
/var/lib/dkms/rtl8812au/5.6.4.2/build/os_dep/linux/ioctl_cfg80211.c: In function ‘rtw_cfg80211_indicate_sta_assoc’:
/var/lib/dkms/rtl8812au/5.6.4.2/build/os_dep/linux/ioctl_cfg80211.c:4449:3: error: implicit declaration of function ‘cfg80211_sinfo_alloc_tid_stats’; did you mean ‘cfg80211_inform_bss_width’? [-Werror=implicit-function-declaration]
cfg80211_sinfo_alloc_tid_stats(&sinfo, GFP_KERNEL);
This appears to be related to this GitHub issue.
I tried this again after editing the Makefile so CONFIG_PLATFORM_ARM_NV_NANO = y, but this still failed.
*github . com /gordboy/rtl8812au-5.6.4.2 (link max rule for new users)
kathyreid@kathyreid-jetson-nano:~/rtl8812au-5.6.4.2$ make
make ARCH=aarch64 CROSS_COMPILE= -C /lib/modules/4.9.140-tegra/build M=/home/kathyreid/rtl8812au-5.6.4.2 modules
make[1]: Entering directory '/usr/src/linux-headers-4.9.140-tegra-ubuntu18.04_aarch64/kernel-4.9'
make[1]: Leaving directory '/usr/src/linux-headers-4.9.140-tegra-ubuntu18.04_aarch64/kernel-4.9'
Makefile:2271: recipe for tar
Any other ideas / advice / drivers that actually work?
Best, Kathy
