Description
sudo apt install ./sdkmanager_1.6.1-8175_amd64.deb
Reading package lists… Done
Building dependency tree
Reading state information… Done
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
libnvinfer-dev : Depends: libcudnn8-dev but it is not installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
anamika@tensorbook:~/Downloads$ sudo apt --fix-broken install
Correcting dependencies… Done
The following packages were automatically installed and are no longer required:
linux-headers-5.4.0-87-generic linux-hwe-5.4-headers-5.4.0-87
linux-image-5.4.0-87-generic linux-modules-5.4.0-87-generic
linux-modules-extra-5.4.0-87-generic
Use ‘sudo apt autoremove’ to remove them.
The following additional packages will be installed:
libcudnn8-dev
The following NEW packages will be installed:
libcudnn8-dev
0 upgraded, 1 newly installed, 0 to remove and 229 not upgraded.
2 not fully installed or removed.
Need to get 0 B/243 MB of archives.
After this operation, 761 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database … 348159 files and directories currently installed.)
Preparing to unpack …/libcudnn8-dev_8.3.1.22-1+cuda10.2_amd64.deb …
Unpacking libcudnn8-dev (8.3.1.22-1+cuda10.2) …
dpkg: error processing archive /var/cache/apt/archives/libcudnn8-dev_8.3.1.22-1+cuda10.2_amd64.deb (–unpack):
trying to overwrite ‘/usr/lib/x86_64-linux-gnu/libcudnn.so’, which is also in package libcudnn-dev:amd64 7.6.4-0lambda1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Environment
TensorRT Version:
GPU Type:
Nvidia Driver Version:
CUDA Version:
CUDNN Version:
Operating System + Version:
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
https://developer.nvidia.com/jetpack-sdk-46
Steps To Reproduce
Download jetpack 4.6 in Ubuntu 18.04.3 LTS tensorbook
sudo apt install ./sdkmanager_[version]-[build#]_amd64.deb
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
