Trying to install sdkmanager2.1.0-12021
I am attempting to install sdk manager 2.2.0-12021 version to be used in installing an image to my target Jetson nanoB01 development kit.
Going thru the instructions after successfully performed the down load and installation of above SDK manager version, I attempted to perform a docker load an my host computer running ubuntu 18.04
magic@magic-OptiPlex-5250-AIO:~/Downloads$ docker load -i ./sdkmanager-2.2.0.12021-Ubuntu_18.04_docker.tar.gz
permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post “http://%2Fvar%2Frun%2Fdocker.sock/v1.24/images/load?quiet=0”: dial unix /var/run/docker.sock: connect: permission denied
Can you assist me in moving past this problem??
Thanks again for your support
Warmly, Bob
Hi @rjaffeco
What happens if you try running the command with sudo?
Regards!
Eduardo Salazar
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
