I am folowing the instructions on Tensorflow’s website 使用 pip 安装 TensorFlow
This is some of the output I got when I entered commands such lspci and lsmod which I found on other posts on this forum.
Here is the bug report nvidia-bug-report.txt - Google Drive
I have tried to blacklist nouveau, but I am not sure if it actually happened. I am pretty new to all of this. Thank you for your help.
The error message when I do nvidia-smi is no device was found.
[ 1.893411] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 418.67 Sat Apr 6 03:07:24 CDT 2019
[ 6.848861] NVRM: RmInitAdapter failed! (0x26:0xffff:1106)
[ 6.848890] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 131.885001] NVRM: RmInitAdapter failed! (0x26:0xffff:1106)
[ 131.885060] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 132.222254] NVRM: RmInitAdapter failed! (0x26:0xffff:1106)
[ 132.222314] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 132.594623] NVRM: RmInitAdapter failed! (0x26:0xffff:1106)
[ 132.594674] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 132.889338] NVRM: RmInitAdapter failed! (0x26:0xffff:1106)
[ 132.889390] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 133.211377] NVRM: RmInitAdapter failed! (0x26:0xffff:1106)
[ 133.211437] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 133.525771] NVRM: RmInitAdapter failed! (0x26:0xffff:1106)
[ 133.525843] NVRM: rm_init_adapter failed for device bearing minor number 0
0a:00.0 VGA compatible controller: NVIDIA Corporation Device 1f06 (rev a1) (prog-if 00 [VGA controller])
0a:00.1 Audio device: NVIDIA Corporation Device 10f9 (rev a1)
0a:00.2 USB controller: NVIDIA Corporation Device 1ada (rev a1) (prog-if 30 [XHCI])
0a:00.3 Serial bus controller [0c80]: NVIDIA Corporation Device 1adb (rev a1)
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
nvidiafb 49152 0
vgastate 24576 1 nvidiafb
fb_ddc 16384 1 nvidiafb
nvidia_uvm 798720 0
nvidia_drm 45056 0
nvidia_modeset 1093632 1 nvidia_drm
nvidia 17895424 2 nvidia_uvm,nvidia_modeset
drm_kms_helper 167936 1 nvidia_drm
drm 401408 3 drm_kms_helper,nvidia_drm
i2c_algo_bit 16384 2 nvidiafb,igb
ipmi_msghandler 53248 2 ipmi_devintf,nvidia
nvidia-bug-report.txt (1.26 MB)
