Trying to put a BlueField-2 into BlueField-X mode with power cycle
Used sudo mlxconfig -d /dev/mst/mt41686_pciconf0 s PCI_DOWNSTREAM_PORT_OWNER[4]=0xF
to set up X mode on a BlueField 2. Then
the DOCA manual says " Power cycle is required for configuration to take effect. To power cycle the host run:
host# ipmitool power cycle
however when I run:
/usr/share/bash-completion/completions/ipmitool power cycle
or
sudo /usr/share/bash-completion/completions/ipmitool power cycle
nothing seems to happen. Can I just power cycle the entire server instead?
using a separately controlled power cycle worked with the Bluefield going into X-mode.
admin@localhost:~> sudo mst start
Starting MST (Mellanox Software Tools) driver set
Loading MST PCI module - Success
Loading MST PCI configuration module - Success
Create devices
-W- Missing "lsusb" command, skipping MTUSB devices detection
Unloading MST PCI module (unused) - Success
admin@localhost:~> sudo mlxconfig -d /dev/mst/mt41686_pciconf0 q PCI_DOWNSTREAM_PORT_OWNER[4]
Device #1:
Device type:    BlueField2
Description:    BlueField-2 P-Series DPU 25GbE Dual-Port SFP56; PCIe Gen4 x8; Crypto and Secure Boot Enabled; 16GB on-board DDR; 1GbE OOB management; HHHL
Device:         /dev/mst/mt41686_pciconf0
Configurations:                              Next Boot
         PCI_DOWNSTREAM_PORT_OWNER[4]        EMBEDDED_CPU(15) ```
