Using tensorrt 8.2.19 on jetson nano 4 gb
I converted the model face detect from nvidia to a tensorrt model (.engine)
face_detector1.py (8.6 KB)
i am trying to get the output from it but always i get that error
ValueError: could not broadcast input array from shape (150528) into shape (276480)
[03/13/2023-03:39:36][TRT] [E] 1: [defaultAllocator.cpp::deallocate::35] Error
We have a sample to run a serialized engine in python.
Please check if your model can work with the sample or not first.
https://elinux.org/Jetson/L4T/TRT_Customized_Example#OpenCV_with_PLAN_model
Hello
I tried the sample with the facedetect model (.engine)
i have jetpack 4.6 , OS 18.04 , python 3.6 ,tensorrt 8.2.19
Always i got that error
[03/14/2023-01:33:13] [TRT] [I] [MemUsageChange] Init CUDA: CPU +224, GPU +0, now: CPU 265, GPU 3211 (MiB)
[03/14/2023-01:33:13] [TRT] [I] Loaded engine size: 9 MiB
[03/14/2023-01:33:13] [TRT] [W] Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
[03/14/2023-01:33:14] [TRT] [I] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +158, GPU +164, now: CPU 423, GPU 3375 (MiB)
[03/14/2023-01:33:16] [TRT] [I] [MemUsageChange] Init cuDNN: CPU +241, GPU +168, now: CPU 664, GPU 3543 (MiB)
[03/14/2023-01:33:16] [TRT] [I] [MemUsageChange] TensorRT-managed allocation in engine deserialization: CPU +0, GPU +9, now: CPU 0, GPU 9 (MiB)
File “nvidia_test.py”, line 88, in
engine = PrepareEngine()
File “nvidia_test.py”, line 73, in PrepareEngine
size = trt.volume(engine.get_tensor_shape(binding)) * batch
AttributeError: ‘tensorrt.tensorrt.ICudaEngine’ object has no attribute ‘get_tensor_shape’
[03/14/2023-01:33:18] [TRT] [E] 1: [defaultAllocator.cpp::deallocate::35] Error Code 1: Cuda Runtime (invalid argument)
I tried running this code but i got this error
File "nvidia_test.py", line 88, in <module>
File "nvidia_test.py", line 73, in PrepareEngine
AttributeError: 'tensorrt.tensorrt.ICudaEngine' object has no attribute 'get_tensor_shape'
The script is for TensorRT 8.4 API.
For TensorRT 8.2 library, please apply the following change:
diff --git a/infer.py b/infer.py
index bf8657c..3281a60 100644
--- a/infer.py
+++ b/infer.py
@@ -44,12 +44,12 @@ def PrepareEngine():
# create buffer
for binding in engine:
- size = trt.volume(engine.get_tensor_shape(binding)) * batch
+ size = trt.volume(engine.get_binding_shape(binding)) * batch
host_mem = cuda.pagelocked_empty(shape=[size],dtype=np.float32)
cuda_mem = cuda.mem_alloc(host_mem.nbytes)
bindings.append(int(cuda_mem))
- if engine.get_tensor_mode(binding)==trt.TensorIOMode.INPUT:
+ if engine.binding_is_input(binding):
host_inputs.append(host_mem)
cuda_inputs.append(cuda_mem)
else:
Thanks astaLLL you were very helpful
but i got another problem in the Inference function
astalll.py (1.7 KB)
[03/23/2023-01:37:48] [TRT] [I] [MemUsageChange] Init CUDA: CPU +224, GPU +0, now: CPU 265, GPU 2661 (MiB)
[03/23/2023-01:37:48] [TRT] [I] Loaded engine size: 9 MiB
[03/23/2023-01:37:48] [TRT] [W] Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
[03/23/2023-01:37:49] [TRT] [I] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +158, GPU +157, now: CPU 423, GPU 2818 (MiB)
[03/23/2023-01:37:50] [TRT] [I] [MemUsageChange] Init cuDNN: CPU +241, GPU +241, now: CPU 664, GPU 3059 (MiB)
[03/23/2023-01:37:50] [TRT] [I] [MemUsageChange] TensorRT-managed allocation in engine deserialization: CPU +0, GPU +9, now: CPU 0, GPU 9 (MiB)
File "astalll.py", line 64, in <module>
Inference(engine)
File "astalll.py", line 23, in Inference
np.copyto(host_inputs[0], image.ravel())
File "<__array_function__ internals>", line 6, in copyto
ValueError: could not broadcast input array from shape (196608) into shape (276480)
[03/23/2023-01:37:53] [TRT] [E] 1: [defaultAllocator.cpp::deallocate::35] Error Code 1: Cuda Runtime (invalid argument)
Based on the log:
\np.copyto(host_inputs[0], image.ravel())
The input image is not the same size as the model input.
You can use OpenCV to rescale the image to align the model size.
