Trying to Save full Frame in the deepstream Image meta example
• DeepStream Version
• TensorRT Version
Hi Team,
I am using the Deep stream 6.0 sdk in ubuntu machine locally, I am following the example of deepstream -image-meta -test for saving the full frame, instead of obj_meta I am passing the frame_meta Like this NvDsUserMetaList *usrMetaList = frame_meta->frame_user_meta_list but its giving segmentation fault , So I tried with these lines of code in osd _sink_pad_buffer_probe as mentioned below
GstMapInfo inmap;
if (gst_buffer_map (buf, &inmap, GST_MAP_READ)) {
char fileNameString[FILE_NAME_SIZE];
const char *osd_string = “OSD”;
snprintf (fileNameString, FILE_NAME_SIZE, “%s_%d_%d.jpg”,
osd_string, frame_number, frame_meta->source_id);
FILE *file = fopen (fileNameString, “wb”);
if (inmap.data != NULL && inmap.size > 0){
g_print(“\n map.size %ld \n”,inmap.size);
fwrite (inmap.data, sizeof (guint8), inmap.size, file);
fclose (file);
gst_buffer_unmap (buf, &inmap);
I am getting the output as OSD image, but no data written on it its size is in kb, I am not sure whether it’s a full frame image or not Can anyone help me to resolve this issue and get full frame after inferencing.
• TensorRT Version
Hardware: RTX1080TI
Deep stream Version :6.0
TensorRT Version:8.0.1
please refer to this topic 239727, it can save the whole frame.
Hi Fanzh Thank you, Now I’m getting the full frame but the size. is 64 bytes. Only not able to view the Image. Can you help me on this?
are you testing in 6.0 docker? could you simplify the code to reproduce this issue?
