I have a kernel which has structure for doing multiplication to that of wmma_example
from code-samples/posts/tensor-cores/simpleTensorCoreGEMM.cu at master · NVIDIA-developer-blog/code-samples · GitHub, and I’m trying to understand why the Nvidia Nsight Compute is complaining about excessive loads.
__global__ void wmma_example(half *a, half *b, float *c, int M, int N, int K, float alpha, float beta) {
// Leading dimensions. Packed with no transpositions.
int lda = M;
int ldb = K;
int ldc = M;
// Tile using a 2D grid
int warpM = (blockIdx.x * blockDim.x + threadIdx.x) / warpSize;
int warpN = (blockIdx.y * blockDim.y + threadIdx.y);
// Declare the fragments
wmma::fragment<wmma::matrix_a, WMMA_M, WMMA_N, WMMA_K, half, wmma::col_major> a_frag;
wmma::fragment<wmma::matrix_b, WMMA_M, WMMA_N, WMMA_K, half, wmma::col_major> b_frag;
wmma::fragment<wmma::accumulator, WMMA_M, WMMA_N, WMMA_K, float> acc_frag;
wmma::fragment<wmma::accumulator, WMMA_M, WMMA_N, WMMA_K, float> c_frag;
wmma::fill_fragment(acc_frag, 0.0f);
// Loop over k
for (int i = 0; i < K; i += WMMA_K) {
int aRow = warpM * WMMA_M;
int aCol = i;
int bRow = i;
int bCol = warpN * WMMA_N;
// Bounds checking
if (aRow < M && aCol < K && bRow < K && bCol < N) {
// Load the inputs
wmma::load_matrix_sync(a_frag, a + aRow + aCol * lda, lda);
wmma::load_matrix_sync(b_frag, b + bRow + bCol * ldb, ldb);
// Perform the matrix multiplication
wmma::mma_sync(acc_frag, a_frag, b_frag, acc_frag);
// Load in the current value of c, scale it by beta, and add this our result scaled by alpha
int cRow = warpM * WMMA_M;
int cCol = warpN * WMMA_N;
if (cRow < M && cCol < N) {
wmma::load_matrix_sync(c_frag, c + cRow + cCol * ldc, ldc, wmma::mem_col_major);
#pragma unroll
for(int i=0; i < c_frag.num_elements; i++) {
c_frag.x[i] = alpha * acc_frag.x[i] + beta * c_frag.x[i];
// Store the output
wmma::store_matrix_sync(c + cRow + cCol * ldc, c_frag, ldc, wmma::mem_col_major);
More importantly I want to look at the first loop, in which for instructions wmma::load_matrix_sync
seem to be the place which are generating excessive loads. Now from my understanding, a warp should be bringing in 16x16 half-float elements into the register file. And since the warp steps to the immediately consecutive column, it should be coalesced. So, why does Nsight complain about only using 16 out of 32 bytes? Isn’t the memory access coalesced throughout the kernel?
