Trying to use cosmos-nemotron-34b but not getting timestamps in output
I am using cosmos-nemotron-34b to convert the video in text, while using the code from nvidia itself it is returning me the summary without the timestamps, in you r documentation it is mentioned that this model returns timestamps in metadata so am I missing something here.
Pasting the code:
import requests
import os
import uuid
import sys
invoke_url = “https://ai.api.nvidia.com/v1/vlm/nvidia/cosmos-nemotron-34b
stream = False
query = “Describe the scene”
kApiKey = os.getenv(“TEST_NVCF_API_KEY”, “”)
assert kApiKey, “Generate API_KEY and export TEST_NVCF_API_KEY=xxxx”
kNvcfAssetUrl = “https://api.nvcf.nvidia.com/v2/nvcf/assets
ext: {mime, media}
kSupportedList = {
“png”: [“image/png”, “img”],
“jpg”: [“image/jpg”, “img”],
“jpeg”: [“image/jpeg”, “img”],
“mp4”: [“video/mp4”, “video”],
def get_extention(filename):
_, ext = os.path.splitext(filename)
ext = ext[1:].lower()
return ext
def mime_type(ext):
return kSupportedList[ext][0]
def media_type(ext):
return kSupportedList[ext][1]
def _upload_asset(media_file, description):
ext = get_extention(media_file)
assert ext in kSupportedList
data_input = open(media_file, “rb”)
headers={
“Authorization”: f"Bearer {kApiKey}“,
“Content-Type”: “application/json”,
“accept”: “application/json”,
assert_url = kNvcfAssetUrl
authorize = requests.post(
assert_url,
headers = headers,
json={“contentType”: f”{mime_type(ext)}", “description”: description},
timeout=30,
authorize.raise_for_status()
authorize_res = authorize.json()
print(f"uploadUrl: {authorize_res['uploadUrl']}")
response = requests.put(
    authorize_res["uploadUrl"],
    data=data_input,
    headers={
        "x-amz-meta-nvcf-asset-description": description,
        "content-type": mime_type(ext),
    timeout=300,
response.raise_for_status()
if response.status_code == 200:
    print(f"upload asset_id {authorize_res['assetId']} successfully!")
else:
    print(f"upload asset_id {authorize_res['assetId']} failed.")
return uuid.UUID(authorize_res["assetId"])
def _delete_asset(asset_id):
headers = {
assert_url = f”{kNvcfAssetUrl}/{asset_id}"
response = requests.delete(
assert_url, headers=headers, timeout=30
def chat_with_media_nvcf(infer_url, media_files, query: str, stream: bool = False):
asset_list =
ext_list =
media_content = “”
assert isinstance(media_files, list), f"{media_files}"
print(“uploading {media_files} into s3”)
has_video = False
for media_file in media_files:
assert ext in kSupportedList, f"{media_file} format is not supported"
if media_type(ext) == “video”:
has_video = True
asset_id = _upload_asset(media_file, “Reference media file”)
asset_list.append(f"{asset_id}“)
ext_list.append(ext)
media_content += f’<{media_type(ext)} src=“data:{mime_type(ext)};asset_id,{asset_id}” />’
if has_video:
assert len(media_files) == 1, “Only single video supported.”
asset_seq = “,”.join(asset_list)
print(f"received asset_id list: {asset_seq}”)
headers = {
“Authorization”: f"Bearer {kApiKey}",
“NVCF-INPUT-ASSET-REFERENCES”: asset_seq,
“NVCF-FUNCTION-ASSET-IDS”: asset_seq,
“Accept”: “application/json”,
if stream:
headers[“Accept”] = “text/event-stream”
response = None
messages = [
        "role": "user",
        "content": f"{query} {media_content}",
payload = {
    "max_tokens": 1024,
    "temperature": 0.2,
    "top_p": 0.7,
    "seed": 50,
    "num_frames_per_inference": 8,
    "messages": messages,
    "stream": stream,
    "model": "nvidia/vila",
response = requests.post(infer_url, headers=headers, json=payload, stream=stream)
if stream:
    for line in response.iter_lines():
        if line:
            print(line.decode("utf-8"))
else:
    print(response.json())
print(f"deleting assets: {asset_list}")
for asset_id in asset_list:
if name == “main”:
“”" export TEST_NVCF_API_KEY=xxx.
python test.py sample.mp4
if len(sys.argv) <= 1:
    print("Usage: export TEST_NVCF_API_KEY=xxx")
    print(f"       python {sys.argv[0]} sample1.png sample2.png ... sample16.png")
    print(f"       python {sys.argv[0]} sample.mp4")
    sys.exit(1)
media_samples = list(sys.argv[1:])
chat_with_media_nvcf(invoke_url, media_samples, query, stream)
