Hello:
I’m trying to use some __device__
memory that holds some useful values (read-only). So, starting from some code I already have, this is the overview
//BigInteger.h
#if CUDA_ENABLED == 1
__device__ static BigInteger _cZERO;
__device__ static BigInteger _cONE;
__device__ static BigInteger _cTWO;
__device__ static BigInteger _cTHREE;
__device__ static BigInteger _cFOUR;
__device__ static BigInteger _cFIVE;
__device__ static BigInteger _cSIX;
__device__ static BigInteger _cSEVEN;
__device__ static BigInteger _cEIGHT;
__device__ static BigInteger _cNINE;
__device__ static BigInteger _cTEN;
__device__ static BigInteger _cHUND;
__device__ static BigInteger _cMIN;
#endif
static BigInteger _ZERO;
static BigInteger _ONE;
static BigInteger _TWO;
static BigInteger _THREE;
static BigInteger _FOUR;
static BigInteger _FIVE;
static BigInteger _SIX;
static BigInteger _SEVEN;
static BigInteger _EIGHT;
static BigInteger _NINE;
static BigInteger _TEN;
static BigInteger _HUND;
static BigInteger _MIN;
Then, on the code:
//BigInteger.c
void _BI_initialize() {
int i = 0;
//lo creamos manualmente ya que clean copia de _ZERO
for (; i < MAX_LENGTH; i++)
_ZERO.n[i] = 0;
_ZERO.count = 0;
_ZERO.k = 'i';
newBI(&_ONE, "1", 0);
newBI(&_TWO, "2", 0);
newBI(&_THREE, "3", 0);
newBI(&_FOUR, "4", 0);
newBI(&_FIVE, "5", 0);
newBI(&_SIX, "6", 0);
newBI(&_SEVEN, "7", 0);
newBI(&_EIGHT, "8", 0);
newBI(&_NINE, "9", 0);
newBI(&_TEN, "10", 0);
newBI(&_HUND, "100", 0);
newBI(&_MIN, "1", -1);
//copy variables to device
cudaMemcpyToSymbol(&_cZERO, &_ZERO, sizeof(BigInteger), cudaMemcpyHostToDevice);
cudaMemcpyToSymbol(&_cONE, &_ONE, sizeof(BigInteger), cudaMemcpyHostToDevice);
cudaMemcpyToSymbol(&_cTWO, &_TWO, sizeof(BigInteger), cudaMemcpyHostToDevice);
cudaMemcpyToSymbol(&_cTHREE, &_THREE, sizeof(BigInteger), cudaMemcpyHostToDevice);
cudaMemcpyToSymbol(&_cFOUR, &_FOUR, sizeof(BigInteger), cudaMemcpyHostToDevice);
cudaMemcpyToSymbol(&_cFIVE, &_FIVE, sizeof(BigInteger), cudaMemcpyHostToDevice);
cudaMemcpyToSymbol(&_cSIX, &_SIX, sizeof(BigInteger), cudaMemcpyHostToDevice);
cudaMemcpyToSymbol(&_cSEVEN, &_SEVEN, sizeof(BigInteger), cudaMemcpyHostToDevice);
cudaMemcpyToSymbol(&_cEIGHT, &_EIGHT, sizeof(BigInteger), cudaMemcpyHostToDevice);
cudaMemcpyToSymbol(&_cNINE, &_NINE, sizeof(BigInteger), cudaMemcpyHostToDevice);
cudaMemcpyToSymbol(&_cTEN, &_TEN, sizeof(BigInteger), cudaMemcpyHostToDevice);
cudaMemcpyToSymbol(&_cHUND, &_HUND, sizeof(BigInteger), cudaMemcpyHostToDevice);
cudaMemcpyToSymbol(&_cMIN, &_MIN, sizeof(BigInteger), cudaMemcpyHostToDevice);
#endif
It compiles without problem, then when I run the code I checked
sizeof(BigInteger) = sizeof(_cZERO) = sizeof(_ZERO) = 4104
- After
cudaMemcpyToSymbol()
any_device_
variable has been changed (seen on the VisualStudio debug panel).
What am I missing?
