Hello, I have a somewhat urgent problem here: Is it possible to use the MMApi Sample “00_video_decode” to decode a MPEG4 or TS only file ?
Given that only TS is stored in a file I can readout this file, but get decoding errors. The frametypes (B,I), framerate, resolution etc. is correctly identified, but decoding seems to fail somehow.
Is it in principle possible to modify the example to be able to use it? Gstreamer or ffmpeg is no option as this decoding will later be embedded in some other application.
One important point to mention: We are working with an “old” MMApi version from 2017 …
Thanks for any hint!
