Every few hours of run time (3-4 hours), I see /dev/ttyTHS2 fill with 0x00 in place of the actual data coming from a GPS module. I’ve set UART traces on the GPS module itself to confirm the module is not the one sending 0x00. In user space I made some logs to output what was being read from /dev/ttyTHS2 and confirmed this behavior with a hexdump on /dev/ttyTHS2. Below is an example of the log output.
As you mentioned my post in your request (link 4) I can confirm that I got the same problem as you without finding any solution. Sometimes we received bunch of zeros on ttyTHS1.
My team and me have concluded that it is a Nvidia bug never corrected. I hope that your post will get a CORRECT reply from a Nvidia Engineer to solve this problem definitively !
(Nota : today we work with a USB-to-serial converter on /dev/ttyUSB0 ).
rgds, Bernard
Messages come across the the UART lines at ~4Hz. This will typically happens for one message at a time. However, I have seen it send 0x00 for 4 messages in a row, meaning we have a loss of data for 1500ms.
It appears we’ve stumbled upon a “solution” to this issue. The upstream device tree from Nvidia does not completely enable the RX DMA for UARTC (possibly all of them). This forces PIO mode for receiving on that UART.
Added dma-names = "rx", "tx"; to the &uartc attribute in the device tree, in my case nvidia/platform/t210/porg/kernel-dts/tegra210.dts.
In a 15 hour test, there were no corrupted messages. Testing will continue but as of now, this is the accepted solution.
