Tuning a Monte Carlo Algorithm on GPUs: basic question
I am a complete novice with CUDA and so I am probably overlooking something basic here with scoping or something. As I was reading over the first listing in the tutorial I see:
do i=1,N
    tempVal = X(i)*X(i) + Y(i)*Y(i)
if (tempVal < 1) then
temp(i) = 1
      else
	 temp(i) = 0
      endif
So now temp(i) equals either 0 or 1 for all i in 1,N. Right?
Then later we see:
   do i=1,N
     sumA = sumA + temp(i)
     sumSq = sumSq + (temp(i)*temp(i))
Since each value of temp(i) is either 0 or 1, temp(i)temp(i) is just 00=0 or 1*1=1 for each value of i. So sumA is equal to sumSq. Right? And what is the point of independently calculating the same value? And later:
    meanA = sumA / real(N);
    meanSq = sumSq / real(N);
Then doesn’t meanA equal meanSq? And how does that help compute the variance? So what is wrong with my understanding?
No, you’re correct. I considered removing the variance portion from the code since it didn’t matter in this case. But, it’s part of a Monte Carlo algorithm I was using, so decide to leave it in.
  • Mat
