Turn offasset fading when changed
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
Isaac Sim Version
4.5.0
Operating System
Windows 10
ubuntu 24.04
Using the franka life cube environment (lift_env_cfg, joint_pos_env_cfg), when toggling visibilty or moving object, the asset fades out instead of instantly disappearing. I want to capture the scene after using cameras
how can i make it so the rendering instantly makes assets(robot,object) disappear
i tried to use set_world_pose for the object but got a attribute error.
video made using ffmpeg from images of tiledcamera
Please share a screencast video to demonstrate the asset fading effect you are seeing in Isaac Sim.
In the meantime, please upgrade to Isaac Sim 5.0.
im trying to get rid of the murky effect around the cube sometimes the outline from the previous place is in the photo.
pretty sure its caused by the asset fading out when moved so i want the cube to instantly disappear.
Have you had a chance to try upgrading to Isaac Sim 5.0?
I have to keep it at isaac4.5 as its part of a bigger project
I’m having the same Issue with Isaac Sim 5.0 - did anyone find a reason / solution by now?
The problem is caused by the anti-aliasing and denoiser that is turned on by default. These try to “smooth” between frames which causes the issue
    self.sim.render.enable_dl_denoiser = False
    self.sim.render.antialiasing_mode = "FXAA"
antialiasing can be FXAA or off
Thanks everyone for the input.
In the end this turned out not to be an asset/visibility issue but a rendering one. The “ghosting” or fading effect was caused by the default denoiser and anti‑aliasing trying to smooth between frames. Disabling the DL denoiser and switching AA to FXAA (or turning it off) removes the problem in both Isaac Sim 4.5 and 5.0:
self.sim.render.antialiasing_mode = "FXAA"  # or "None"
With this configuration, objects disappear or move without leaving a murky outline, so I’m marking this as solved.
