I wish to turn off runtime output of the form:
TVMR: FrameRate = XX
I’ve Googled for the solution, but haven’t found anything.
I tried using ‘GST_DEBUG=0’ but that didn’t help.
Topic | Replies | Views | Activity | |
Turn off debugging output from NVIDIA GStreamer elements? | 6 | 815 | April 21, 2023 | |
How to disable the messages on the nvvidconv elements? | 4 | 1398 | October 18, 2021 | |
How to turn off video display on screen? | 5 | 581 | October 12, 2021 | |
When the decoder parameter enable-frame-type-reporting is turned on, the console always has output, how to turn it off | 12 | 399 | August 9, 2023 | |
Stream without "enable-frame-type-reporting=1 " does not works | 2 | 989 | June 25, 2021 | |
GStreamer Element nvivafilter has no output | 2 | 412 | October 15, 2021 | |
How to disable Gst report messages in terminal window | 6 | 1444 | September 4, 2021 | |
Disable sink0 | 3 | 349 | October 12, 2021 | |
Deepstream gst-python , no video output | 2 | 357 | October 9, 2021 | |
How to verify if gstreamer is using GPU? | 4 | 3678 | October 18, 2021 |
