Turning off the automatic Smart Record
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.0
• TensorRT Version 8.6.1
• NVIDIA GPU Driver Version (valid for GPU only) 535.183
• Issue Type( questions, new requirements, bugs) questions
I manage to use Smart Record in deepstream-app sample project. However, once I set the smart-record = 2 in configuration, without NvDsSRStart() in pipeline, the app starts recording and generate a 10s video, and keep looping this feature. I refer Smart Record documentation and I find that indeed it has this features. So how could disable automatic Smart Recording when smart-record = 2? Thank you!
please smart-rec-interval to a big number in the configuration file. deepstream-app is opensource. you can find the following code in create_rtsp_src_bin of \opt\nvidia\deepstream\deepstream\sources\apps\apps-common\src\deepstream_source_bin.c
  if (config->smart_record == 2) {
    if (bin->config->smart_rec_interval)
      g_timeout_add (bin->config->smart_rec_interval * 1000,
          smart_record_event_generator, bin);
    else
      g_timeout_add (10000, smart_record_event_generator, bin);
Thanks for your reply. I commented the code you mentioned, and it worked.
