it might be not the solution that you are looking for but if you have a spare sdcard or could reflash present sdcard I would suggest to try again from scratch.
I was not able to run into issues neither on nano , nor on Xavier headless jetsons. The only thing was to follow the original steps but not literally , but building all packages from sources.
also here I used 64 instead of 32
sudo vi /etc/ld.so.conf.d/libjpeg-turbo.conf
Add the following line
/opt/libjpeg-turbo/lib32—>/opt/libjpeg-turbo/lib64
source [HowTo]Install VirtualGL and TurboVNC to Jetson TK1
