Tutorial: Setup Deepstream C development enviornment with CMake and VSCode
This tutorial show how to create a debug enviornment with VScode. It also have code nagivation
Prequirements
  • CMake > 3.25
sudo apt-get update
sudo apt-get install ca-certificates gpg wget
test -f /usr/share/doc/kitware-archive-keyring/copyright ||
wget -O - https://apt.kitware.com/keys/kitware-archive-latest.asc 2>/dev/null | gpg --dearmor - | sudo tee /usr/share/keyrings/kitware-archive-keyring.gpg >/dev/null
# For Ubuntu Jammy Jellyfish (22.04):
echo 'deb [signed-by=/usr/share/keyrings/kitware-archive-keyring.gpg] https://apt.kitware.com/ubuntu/ jammy main' | sudo tee /etc/apt/sources.list.d/kitware.list >/dev/null
sudo apt-get update
# For Ubuntu Focal Fossa (20.04):
echo 'deb [signed-by=/usr/share/keyrings/kitware-archive-keyring.gpg] https://apt.kitware.com/ubuntu/ focal main' | sudo tee /etc/apt/sources.list.d/kitware.list >/dev/null
sudo apt-get update
sudo rm /usr/share/keyrings/kitware-archive-keyring.gpg
sudo apt-get install kitware-archive-keyring
sudo apt-get install cmake
  • VSCode
  • clangd
sudo apt-get install clangd-12
  • package to run this example
sudo apt-get install libgstreamer-plugins-base1.0-dev libgstreamer1.0-dev \
   libgstrtspserver-1.0-dev libx11-dev libjson-glib-dev libyaml-cpp-dev
Setup VSCode for development
  • install VSCode extension
    CodeLLDB、clangd 、CMake 、CMake Tools
  • Note: Do not install C/C++ extension pack from Microsoft
  • copy deepstream-test5 to your workspace
    deepstream-test5 is a complete example to modify deepstream-app,this will take the advantage of the module design of deepstream-app. You can add probe to customize the app. It have good config parser and error handling, those will save many effort.
    Following our workspace is in the copy of deepstream-test5 folder.
cp -r /opt/nvidia/deepstream/deepstream/apps/sample_apps/deepstream-test5/* /path/to/your/workspace
  • create launch.json and task.json
    create launch.json and task.json for compile and debug
tasks.json use CMake to build
  "version": "2.0.0",
  "tasks": [
            "type": "cmake",
            "label": "CMake: build",
            "command": "build",
            "targets": [
                "all"
            "group": "build",
            "problemMatcher": [],
            "detail": "CMake template build task"
launch.json call task in task json to build
    // Use IntelliSense to learn about possible attributes.
    // Hover to view descriptions of existing attributes.
    // For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387
    "version": "0.2.0",
    "configurations": [
            "type": "lldb",
            "request": "launch",
            "name": "Debug",
            "program": "${workspaceFolder}/deepstream-test5",//the path of the executable file deepstream-test5
            "args": ["-c", "configs/test5_config_file_src_infer.txt"],//arg for deepstream-test5
            "cwd": "${workspaceFolder}",//指定工作目錄
            "preLaunchTask": "CMake: build"
create settings.json for clangd to read compile_commands.json. clangd can generate code navigator.
    "cmake.sourceDirectory": "${workspaceFolder}",
    "cmake.generator": "Unix Makefiles",
    "clangd.arguments": [
        "--compile-commands-dir=${workspaceFolder}/build",
        "--background-index",
        "-j=8",
        "--query-driver=/usr/bin/clang++",
        "--clang-tidy",
        "--clang-tidy-checks=performance-*,bugprone-*",
        "--all-scopes-completion",
        "--completion-style=detailed",
        "--function-arg-placeholders",
        "--header-insertion=iwyu",
        "--pch-storage=memory",
  • Create CMAKELists.txt
    Create CMakeLists.txt under the workspace folder, CMake will help you find CUDA and nvcc, no more CUDA_VER env variable needed even in jetson.
    In this example,we need to compile deepstream-app first and use the object file in our project.So we use ExternalProject_Add to do this.
We need to change the permission for deepstream-app source folder in order to compile the deepstream-app.
sudo chmod -R 777 /opt/nvidia/deepstream/deepstream/sources/apps/
cmake_minimum_required(VERSION 3.25)
project(deepstream-test5 LANGUAGES C CXX) #project(deepstream-test5 LANGUAGES CUDA C CXX)
set(CMAKE_CXX_STANDARD 14)
set (CMAKE_RUNTIME_OUTPUT_DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR})
set(CMAKE_EXPORT_COMPILE_COMMANDS ON)
set(CMAKE_BUILD_TYPE Debug)
find_package(PkgConfig REQUIRED)
pkg_check_modules(PKGS REQUIRED uuid x11 gstreamer-video-1.0 json-glib-1.0 gstreamer-1.0 gstreamer-rtsp-server-1.0 yaml-cpp)
find_package(CUDAToolkit)
message("CUDA_VER is ${CUDAToolkit_VERSION_MAJOR}.${CUDAToolkit_VERSION_MINOR}")
if(NOT DEFINED CMAKE_CUDA_STANDARD)
    set(CMAKE_CUDA_STANDARD 11)
    set(CMAKE_CUDA_STANDARD_REQUIRED True)
endif()
SET(DEEPSTREAMAPP
include(ExternalProject)
ExternalProject_Add(deepstreamapp
    SOURCE_DIR ${DEEPSTREAMAPP}/sample_apps/deepstream-app
    CONFIGURE_COMMAND ""
    INSTALL_COMMAND ""
    DOWNLOAD_COMMAND ""
    BUILD_COMMAND export CUDA_VER=${CUDAToolkit_VERSION_MAJOR}.${CUDAToolkit_VERSION_MINOR} && make
    BUILD_IN_SOURCE true
file(GLOB_RECURSE  DEEPSTREAMAPPCOMMONOBJ "/opt/nvidia/deepstream/deepstream/sources/apps/apps-common/src/*.o")
file(GLOB_RECURSE  DEEPSTREAMAPPOBJ "/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-app/*.o")
list(REMOVE_ITEM DEEPSTREAMAPPOBJ "/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-app/deepstream_app_main.o")
message(DEEPSTREAMAPPCOMMONOBJ="${DEEPSTREAMAPPCOMMONOBJ}")
message(DEEPSTREAMAPPOBJ="${DEEPSTREAMAPPOBJ}")
SET(OBJS
    ${DEEPSTREAMAPPOBJ}
    /opt/nvidia/deepstream/deepstream/sources/apps/apps-common/src/deepstream_config_file_parser.o
SET_SOURCE_FILES_PROPERTIES(
  ${OBJS}
  PROPERTIES
  EXTERNAL_OBJECT true
  GENERATED true
add_executable(${PROJECT_NAME}
    ${OBJS}
    deepstream_utc.c
    deepstream_test5_app_main.c
target_include_directories(${PROJECT_NAME} PRIVATE
    ${PKGS_INCLUDE_DIRS}
    ${CMAKE_CUDA_TOOLKIT_INCLUDE_DIRECTORIES}
    /opt/nvidia/deepstream/deepstream/sources/apps/apps-common/includes
    /opt/nvidia/deepstream/deepstream/sources/includes
    ${CMAKE_CURRENT_SOURCE_DIR}/cparse
target_link_libraries(${PROJECT_NAME} PRIVATE
    ${PKGS_LIBRARIES}
    CUDA::cuda_driver
    nvds_utils nvdsgst_helper m nvdsgst_meta nvds_meta stdc++
    nvbufsurface nvbufsurftransform nvds_batch_jpegenc uuid jpeg png nvds_yml_parser
    nvdsgst_smartrecord nvds_msgbroker nvdsgst_customhelper
    pthread
    PRIVATE CUDA::cudart
target_link_directories(${PROJECT_NAME} PRIVATE
    /opt/nvidia/deepstream/deepstream/lib/
target_link_options(${PROJECT_NAME} PRIVATE -Wl,-rpath,/opt/nvidia/deepstream/deepstream/lib/)
Nice, thanks for your sharing to the community!
