Hi, when I was trying converting a ReID (person re-identification) model into tensorrt, I encounter two bugs when using onnx-tensorrt tool (https://github.com/onnx/onnx-tensorrt), then I use gdb doing some debug, but because TensorRT is not open sourced, I can’t going down further, so I hope get some help here
The second bug is related to Instance Normalization(I guess), it crashes at this line of code (https://github.com/onnx/onnx-tensorrt/blob/8716c9b32dcc947287f2ede9ef7d563601bb2ee0/main.cpp#L245), when I using gdb backtrace, it seems like the error happens at tensorrt trying to save something like PluginV2Param into a cache, and as far as I know, the only op in our model which needs tensorrt plugin is Instance Normalization.
As the TensorRT 7 has been released, I try to use the newer versions, but the second bug still remains…Here is the detailed gdb backtrace results
(gdb) bt
#0 0x00007fffe7c8c3e5 in __strlen_sse2_pminub () from /usr/lib64/libc.so.6
#1 0x00007fffe84d14c1 in length (__s=0x31 <Address 0x31 out of bounds>)
at /home/xxxx/gcc-5.3.0/x86_64-unknown-linux-gnu/libstdc++-v3/include/bits/char_traits.h:267
#2 std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string (this=0x7fffffffc840,
__s=0x31 <Address 0x31 out of bounds>, __a=...)
at /home/xxxx/gcc-5.3.0/x86_64-unknown-linux-gnu/libstdc++-v3/include/bits/basic_string.tcc:658
#3 0x00007fffe98157cb in nvinfer1::rt::ArchiveWriteUtils::save(nvinfer1::rt::WriteArchive&, nvinfer1::PluginV2Parameters const&) ()
from /world/data-gpu-94/tensorrt/TensorRT-7.0.0.11/lib/libnvinfer.so.7
#4 0x00007fffe9815b35 in nvinfer1::rt::ArchiveWriteUtils::save(nvinfer1::rt::WriteArchive&, nvinfer1::OptionalValue<nvinfer1::rt::cuda::PluginV2DynamicExtRunner> const&) () from /world/data-gpu-94/tensorrt/TensorRT-7.0.0.11/lib/libnvinfer.so.7
#5 0x00007fffe981b06a in nvinfer1::rt::ArchiveWriteUtils::save(nvinfer1::rt::WriteArchive&, nvinfer1::OptionalValue<nvinfer1::rt::Runner> const&) () from /world/data-gpu-94/tensorrt/TensorRT-7.0.0.11/lib/libnvinfer.so.7
#6 0x00007fffe99fe44d in nvinfer1::cudnn::serializeEngine(nvinfer1::rt::Engine const&) ()
#7 0x00007fffe97fcd3f in nvinfer1::rt::Engine::serialize() const ()
#8 0x00000000004086d9 in main (argc=<optimized out>, argv=<optimized out>) at /world/data-gpu-94/tensorrt/onnx-tensorrt/main.cpp:245
