# Two Camera dts sample  without I2C MUX on TX2
**URL:** <https://forums.developer.nvidia.com/t/two-camera-dts-sample-without-i2c-mux-on-tx2/74303>\
**Category:** Jetson TX2\
**Created:** [May 7, 2019, 9:18am UTC](https://forums.developer.nvidia.com/t/two-camera-dts-sample-without-i2c-mux-on-tx2/74303 "2019-05-07T09:18:49Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![27653276](https://developer.download.nvidia.com/images/forums/profile-default-devtalk-84.png) [@27653276](https://forums.developer.nvidia.com/u/27653276)\
**Post date:** [May 7, 2019, 9:18am UTC](https://forums.developer.nvidia.com/t/two-camera-dts-sample-without-i2c-mux-on-tx2/74303/1 "2019-05-07T09:18:49Z")
</div>
With our design, We don’t use the i2C Mux Chip，We set difference I2C address on each Camera sensor,
Are there any dts sample for our reference?
**Post date:** [May 7, 2019, 9:51am UTC](https://forums.developer.nvidia.com/t/two-camera-dts-sample-without-i2c-mux-on-tx2/74303/2 "2019-05-07T09:51:25Z")
</div>
It Look like the tegra186-quill-camera-e3323-a00.dtsi is a similar sample code,
the dts file support two camera connect to I2C Bus(i2c@3180000-\>cam\_i2c and i2c@240000-\>gen2\_i2c)
For my design, I just need to change to the same i2c bus address,correctly?
**Author:** ![ShaneCCC](https://sea2.discourse-cdn.com/nvidia/user_avatar/forums.developer.nvidia.com/shaneccc/32/14043_2.png) [@ShaneCCC](https://forums.developer.nvidia.com/u/ShaneCCC)\
**Post date:** [May 8, 2019, 4:41am UTC](https://forums.developer.nvidia.com/t/two-camera-dts-sample-without-i2c-mux-on-tx2/74303/3 "2019-05-08T04:41:15Z")
</div>
You can reference to the e3333 and remove the i2c-mux define.
If you connect to different bus you can reference to e3323 as you found.
**Author:** ![nadeemm](https://sea2.discourse-cdn.com/nvidia/user_avatar/forums.developer.nvidia.com/nadeemm/32/367020_2.png) [@nadeemm](https://forums.developer.nvidia.com/u/nadeemm)\
**Post date:** [October 18, 2021, 6:32pm UTC](https://forums.developer.nvidia.com/t/two-camera-dts-sample-without-i2c-mux-on-tx2/74303/4 "2021-10-18T18:32:21Z")
</div>
