Two cameras on Production Module without I2C HUB
I’m trying to run two IMX477 cameras on custom board without I2C Mux. I tried removing definitions about
i2cmux, but then module wouldn’t boot.
I checked NANO multi CSI without I2C HUB, but the solution seems not to apply for my problem.
	i2c@7000c400 {
		#address-cells = <0x1>;
		#size-cells = <0x0>;
		compatible = "nvidia,tegra210-i2c";
		reg = <0x0 0x7000c400 0x0 0x100>;
		interrupts = <0x0 0x54 0x4>;
		iommus = <0x30 0xe>;
		status = "okay";
		clock-frequency = <0x186a0>;
		dmas = <0x51 0x16 0x51 0x16>;
		dma-names = "rx", "tx";
		clocks = <0x26 0x36 0x26 0xf3>;
		clock-names = "div-clk", "parent";
		resets = <0x26 0x36>;
		reset-names = "i2c";
		linux,phandle = <0x10e>;
		phandle = <0x10e>;
		prod-settings {
			prod_c_sm {
				prod = <0x94 0xffffffff 0x304 0x6c 0xffffffff 0x160001>;
		i2cmux@70 {
			compatible = "nxp,pca9546";
			reg = <0x70>;
			vcc-supply = <0x4c>;
			vcc-pullup-supply = <0x4c>;
			status = "disabled";
			linux,phandle = <0xbe>;
			phandle = <0xbe>;
			i2c@0 {
				reg = <0x0>;
				i2c-mux,deselect-on-exit;
			i2c@1 {
				reg = <0x1>;
				ina3221x@40 {
					compatible = "ti,ina3221x";
					reg = <0x40>;
					ti,trigger-config = <0x7003>;
					ti,continuous-config = <0x7c07>;
					ti,enable-forced-continuous;
					channel@0 {
						reg = <0x0>;
						ti,rail-name = "VDD_5V";
						ti,shunt-resistor-mohm = <0xa>;
					channel@1 {
						reg = <0x1>;
						ti,rail-name = "VDD_3V3";
					channel@2 {
						reg = <0x2>;
						ti,rail-name = "VDD_1V8";
						ti,shunt-resistor-mohm = <0x1>;
tegra210-p3448-0002-p3449-0000-b00-user-custom.txt (324.9 KB)
I would suggest remove all of the sensor dts file and only include the imx477 to modify it.
