[b]UPDATE - both cameras appear to work now, but only after running the v4l2-compliance tool. Before running the tool, the second camera doesn’t work.
Does anyone know why running v4l2-compliance would make the cameras work? And is there anything I can do to make them work at boot, besides automatically launching that process at startup?[/b]
We have two CSI cameras from E-Con Systems (NileCAM30) that we have successfully modified to work with the Jetson TX2i on an Auvidea J90 carrier board, which has two cameras, on CSI lanes CD and EF.
Each camera works when it is the only one connected. But when booting with both cameras connected at once, although we see two nodes in /dev - video0 and video1, only one of them works correctly. Streaming from the other causes errors. Sometimes the one that works is video0, and sometimes it’s video1, but never both.
We’re not sure what is wrong, as both cameras and both CSI connections are verified to work individually. It’s just that when both cameras are connected at the same time, one of them doesn’t work. And which of the two cameras works seems to change with each boot.
Our device tree files are attached. The specific error we get when trying to use the nonworking camera is:
[ 1013.484299] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1013.490807] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
Also, this message appears:
[ 580.413760] tegra-vi4 15700000.vi: Status: 7 channel:00 frame:0000
[ 580.420040] tegra-vi4 15700000.vi: timestamp sof 605231803040 eof 605241120832 data 0x00000001
[ 580.429463] tegra-vi4 15700000.vi: capture_id 7 stream 2 vchan 0
v4l2-compliance passes for both cameras. Both cameras seem to initialize successfully in dmesg, as shown below:
[ 12.996048] tegra-vi4 15700000.vi: subdev ar0330 1-0042 bound
[ 12.996052] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi-2 bound
[ 12.996425] tegra-vi4 15700000.vi: subdev ar0330 7-0042 bound
[ 12.996429] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi-4 bound
Note that, although we have both cameras using the same reset GPIO, we modified the probe function to only actually toggle it once, and to free up the GPIOs after using them, so we don’t think this is the problem.
Any help would be greatly appreciated, thanks.
tegra186-quill-camera-ar0330.dtsi
/* Econ device tree for AR0330 support */
#include <dt-bindings/media/camera.h>
#include <dt-bindings/platform/t210/t210.h>
#include "dt-bindings/clock/tegra186-clock.h"
#define ECON_CAM0_RST_L TEGRA_MAIN_GPIO(R, 1) /* reset line shared between cameras */
#define ECON_CAM_0_PWDN TEGRA_MAIN_GPIO(R, 2) /* unconnected - assigned to unused GPIO */
#define ECON_HIM_MODE TEGRA_MAIN_GPIO(R, 0) /* unconnected - assigned to unused GPIO */
#define ECON_ADD0_GPIO TEGRA_MAIN_GPIO(R, 3) /* unconnected - assigned to unused GPIO */
#define ECON_ADD1_GPIO TEGRA_MAIN_GPIO(R, 5) /* unconnected - assigned to unused GPIO */
host1x {
vi@15700000 {
num-channels= <2>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
ecam_vi_in2: endpoint {
csi-port = <2>; /* CSI ports C and D */
bus-width = <4>;
remote-endpoint = <&ecam_csi_out2>;
port@1 {
reg = <1>;
ecam_vi_in4: endpoint {
csi-port = <4>; /* CSI ports E and F */
bus-width = <4>;
remote-endpoint = <&ecam_csi_out4>;
nvcsi@150c0000 {
num-channels = <2>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
ecam_csi_in2: endpoint@0 {
bus-width = <4>;
remote-endpoint = <&ecam_ar0330_out2>;
port@1 {
reg = <1>;
ecam_csi_out2: endpoint@1 {
remote-endpoint = <&ecam_vi_in2>;
channel@1 {
reg = <1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
ecam_csi_in4: endpoint@2 {
bus-width = <4>;
remote-endpoint = <&ecam_ar0330_out4>;
port@1 {
reg = <1>;
ecam_csi_out4: endpoint@3 {
remote-endpoint = <&ecam_vi_in4>;
/* CSI-CD is i2c-1 - c2400000 */
/* CSI-EF is i2c-7 - c2500000 */
i2c@c240000 {
status = "okay";
#size-cells = <0>;
ar0330_c@42 {
status = "okay";
compatible = "nvidia,ar0330";
reg = <0x42>;
sensor_model ="ar0330";
avdd-reg = "vana";
iovdd-reg = "vif";
post_crop_frame_drop = "0";
clocks = <&tegra_car TEGRA186_CLK_EXTPERIPH1>,
<&tegra_car TEGRA186_CLK_PLLP_OUT0>;
clock-names = "extperiph1", "pllp_grtba";
mclk = "extperiph1";
clock-frequency = <24000000>;
reset-gpios = <&tegra_main_gpio ECON_CAM0_RST_L GPIO_ACTIVE_HIGH>;
pwdn-gpios = <&tegra_main_gpio ECON_CAM_0_PWDN GPIO_ACTIVE_LOW>;
him-mode = <&tegra_main_gpio ECON_HIM_MODE GPIO_ACTIVE_LOW>;
add0-gpio = <&tegra_main_gpio ECON_ADD0_GPIO GPIO_ACTIVE_HIGH>;
add1-gpio = <&tegra_main_gpio ECON_ADD1_GPIO GPIO_ACTIVE_HIGH>;
vana-supply = <&en_vdd_cam_hv_2v8>;
vif-supply = <&en_vdd_cam>;
mode0 { /* mode AR0330 */
mclk_khz = "37125";
num_lanes = "4";
tegra_sinterface = "serial_c"; /* CSI lanes C-D */
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "12";
csi_pixel_bit_depth = "12";
mode_type = "bayer";
pixel_phase = "rggb";
pixel_t = "uyvy";
active_w = "4192";
active_h = "3120";
readout_orientation = "0";
line_length = "2200";
inherent_gain = "1";
mclk_multiplier = "2";
pix_clk_hz = "74250000";
min_gain_val = "0"; /* dB */
max_gain_val = "48"; /* dB */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "1.5";
max_framerate = "30";
min_exp_time = "30";
max_exp_time = "660000";
embedded_metadata_height = "1";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
ecam_ar0330_out2: endpoint {
bus-width = <4>;
remote-endpoint = <&ecam_csi_in2>;
i2c@c250000 {
status = "okay";
#size-cells = <0>;
ar0330_e@42 {
status = "okay";
reg = <0x42>;
avdd-reg = "vana";
iovdd-reg = "vif";
mclk_khz = "37125";
num_lanes = "4";
tegra_sinterface = "serial_e"; /* CSI lanes E-F */
pixel_t = "uyvy";
active_w = "4192";
active_h = "3120";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
ecam_ar0330_out4: endpoint {
bus-width = <4>;
remote-endpoint = <&ecam_csi_in4>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
modules {
module0 {
badge = "ecam_cu30-1";
position = "front";
orientation = "1";
drivernode0 {
pcl_id = "v4l2_sensor";
devname = "e-CAM30_GMSL_CUTX2_CSI_CD";
proc-device-tree = "/proc/device-tree/i2c@c240000/ar0330_c@42";
status = "okay";
module1 {
badge = "ecam_cu30-2";
position = "rear";
orientation = "1";
drivernode0 {
devname = "e-CAM30_GMSL_CUTX2_CSI_EF";
proc-device-tree = "/proc/device-tree/i2c@c250000/ar0330_e@42";
status = "okay";
gpio@2200000 {
camera-control-output-low {
gpio-hog;
output-low;
gpios = <ECON_CAM0_RST_L 0 ECON_CAM_0_PWDN 1 ECON_ADD0_GPIO 0 ECON_ADD1_GPIO 0>;
label = "cam0-rst", "cam0-pwdn", "add0_gpio", "add1_gpio";
tegra186-quill-p3489-1000-a00-00-ar0330.dts
* Copyright (c) 2016, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; version 2 of the License.
* This program is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
#include "tegra186-quill-p3489-1000-a00-00-ucm1.dts"
#include "quill-platforms/tegra186-quill-camera-ar0330.dtsi"
nvidia,dtsfilename = __FILE__;
host1x {
vi_base: vi@15700000 {
ports {
ecam_vi_port0: port@0 {
status = "okay";
status = "okay";
ecam_vi_port1: port@1 {
status = "okay";
status = "okay";
csi_base: nvcsi@150c0000 {
csi_chan0: channel@0 {
status = "okay";
ports {
csi_chan0_port0: port@0 {
status = "okay";
status = "okay";
csi_chan0_port1: port@1 {
status = "okay";
status = "okay";
csi_chan1: channel@1 {
status = "okay";
ports {
csi_chan1_port0: port@0 {
status = "okay";
status = "okay";
csi_chan1_port1: port@1 {
status = "okay";
status = "okay";
