• Hardware Platform (Jetson / GPU) Jetson AGX xwaiver
• DeepStream Version 5.1
• JetPack Version (valid for Jetson only) 4.3
• TensorRT Version 7.1
- set udp sink output, rtsp port 8554, udp port 5001
- use two agx device on the same local network
- run the deepstream-app on two agx
- you will find the rtsp out on the two device , influence each other. cause green screen , flash screen.
