Two questions about too many threads in a block
Hello all,
I just start practicing cuda programming.
Here I have some questions about the case that too many threads in a block…
Since each block can only have 256 (or 512) threads, how do I acquire this information in my host program?
Meanwhile, what happens if we give too many threads in a block? What can be expected?
For example,
I just wrote a very simple cuda program:
==== following are just pseudo codes ====
==== the kernel ====
global void adder (float *buff) {
int idx = threadIdx.x;
buff[idx] = buff[idx] + 1;
==== the host ====
#define BUFF_SIZE 16
host_buff = malloc(BUFF_SIZE * sizeof(float));
device_buff = cudaMalloc(BUFF_SIZE * sizeof(float));
cudaMemCpy(device_buff, host_buff, BUFF_SIZE * sizeof(float), cudaMemcpyHostToDevice);
adder<<<1, BUFF_SIZE>>>(device_buff);
cudaMemcpy(host_buff, device_buff, BUFF_SIZE * sizeof(float), cudaMemcpyDeviceToHost);
for (int i = 0 ; i < BUFF_SIZE ; i++)
if (host_buff[i] != 1) {
printf(“NOT GOOD\n”);
break;
===== end of pseudo codes ====
This example works well.
However, if I change the “BUFF_SIZE” to 4096!! Obviously, we will have 4096 threads in a block which is not allowed.
In this case, I got every element of the “host_buff” not added!! (so 4096 “NOT GOOD” was printed)
If we put too many threads to a block, does it means cuda will do nothing for us instead of at least does 256 adding for us?
  • Wei-Fan
If you have installed the Nvidia examples, run the program device query and look for the property max threads per block. You should submit the kernel like this
adder<<<(BUFF_SIZE+max_threads-1)/max_treads, max_threads>>>(device_buff);
I think that most of the video cards which support cuda made in the last 2 years have max_threads=512. The fermi cards have 1024. there is a limit for size of the dimension of the blocks.
In general you would use
adder<<<(bx,by,bz),(tx,ty,tz)>>>(device_buff);
with txtytz<=512
bx<=65536
by<=65536
bz<=64
I strongly recommend checking the return status of every CUDA API call and the status of every kernel execution. In addition, I would suggest taking a closer look at the functions cudaGetLastError() and cudaGetErrorString().
Any way the result will be wrong.
Unless you have a compelling reason not to, hard-code the number of threads per block. You can even hard-core the number of blocks per SM. Use the launch_bounds modifier on a kernel function. I wrote a nifty Fermi occupancy table here:
http://www.moderngpu.com/intro/workflow.html#Occupancy
Try to stay above 50% occupancy, although going lower won’t necessarily hurt performance if your kernels have decent ILP. Small blocks are preferred over large blocks. Hard-coding the block size will reduce register pressure and almost certainly increase performance by turning some expressions into compile-time constants.
You can also put some constant number for the threads in the block and use this modified kernel:
global void adder (float *buff,size(buff))
while(idx<size(buff)
idx=idx+blockDim.x;
This way each thread will do more than one addition.
