Hello guys:
I am running omniverse-launcher on ubuntu. I had installed apps: cache, create,isaac sim, nucleus.
The “System Monitor” can not be started.
I found this log below on my local, I think it’s obvious that two omniverse-apps(cache and nucleus) were competing on port 3080, Is there any workaround on this issue.
[2022-05-12 21:19:43,157][OT] INFO: create_config_toml: <bound method MonitorConfig.create_config_toml of <monitor.config.MonitorConfig object at 0x7f4d73ef9eb0>>
debug: 0
discovery_token: test
exe_path: /home/ouyang/app/omniverse/library/nucleus-workstation-2022.1.2/System Monitor
full_name: Omniverse System Monitor
get_log_dir: <bound method MonitorConfig.get_log_dir of <monitor.config.MonitorConfig object at 0x7f4d73ef9eb0>>
log_file: /home/ouyang/.nvidia-omniverse/logs/System Monitor/logs.txt
log_file_count: 5
log_level: INFO
log_size: 5242880
monitor_config_dir: .
monitor_icon: /home/ouyang/app/omniverse/library/nucleus-workstation-2022.1.2/System Monitor/omniverse-system-monitor-np.ico
monitor_service_port: 3085
monitor_ui_port: 3080
omni: <monitor.config.OmniConfig object at 0x7f4d73f050d0>
omni_config_dir: /home/ouyang/.nvidia-omniverse/config
omni_config_toml: /home/ouyang/.nvidia-omniverse/config/omniverse.toml
process_watch_interval: 3
[2022-05-12 21:19:43,158][OT] INFO: Running the web UI on http://localhost:3080
[2022-05-12 21:19:43,158][OT] ERROR: 'bool' object has no attribute 'get'
File "service/runner.py", line 29, in run
File "service/runner.py", line 58, in init_interfaces
File "service/auth.py", line 23, in __init__
File "service/auth.py", line 37, in reload_config
AttributeError: 'bool' object has no attribute 'get'
[2022-05-12 21:19:43,160][OT] INFO: Stopped the web UI.
[2022-05-12 21:19:43,160][OT] ERROR: [Errno 98] error while attempting to bind on address ('127.0.0.1', 3080): address already in use
File "web.py", line 40, in run
File "aiohttp/web_runner.py", line 100, in start
File "asyncio/base_events.py", line 1463, in create_server
OSError: [Errno 98] error while attempting to bind on address ('127.0.0.1', 3080): address already in use
[2022-05-12 21:19:43,177][OT] INFO: create_config_toml: <bound method MonitorConfig.create_config_toml of <monitor.config.MonitorConfig object at 0x7f5156a96f10>>
debug: 0
exe_path: /home/ouyang/app/omniverse/library/cache-2022.1.1/System Monitor
get_log_dir: <bound method MonitorConfig.get_log_dir of <monitor.config.MonitorConfig object at 0x7f5156a96f10>>
log_file_count: 5
log_level: INFO
log_size: 5242880
monitor_icon: /home/ouyang/app/omniverse/library/cache-2022.1.1/System Monitor/omniverse-system-monitor-np.ico
omni: <monitor.config.OmniConfig object at 0x7f5156a96fa0>
[2022-05-12 21:19:43,177][OT] INFO: Running the web UI on http://localhost:3080
[2022-05-12 21:19:43,178][OT] ERROR: 'bool' object has no attribute 'get'
File "service/runner.py", line 30, in run
File "service/runner.py", line 59, in init_interfaces
File "service/auth.py", line 36, in reload_config
[2022-05-12 21:19:43,179][OT] INFO: Stopped the web UI.
[2022-05-12 21:19:43,179][OT] ERROR: [Errno 98] error while attempting to bind on address ('127.0.0.1', 3080): address already in use
