Two threads for two GPUs - what can be wrong ?
I have a main class CContainer that contains all the items that are to be evaluated on GPU. As I have two GPUs, two threads are created fro each of them. Schematically, it is done in this manner:
class CContainer
	static UINT ThreadFunc(void* pData);
	void Thread(); // Here are the calculations
UINT CContainer::ThreadFunc(void* pData)
   ((CCOntainer*)pData)->Thread();
I start ThreadFunc as a thread and everything works just fine.
However, when I decided to implement separate class for calculations, everything stops working with ‘unspecified launch failure’:
class CCalculator
	virtual void Thread() = 0;
UINT CCalculator::ThreadFunc(void* pData)
   ((CCalculator*)pData)->Thread();
class CCalculator_GPU : public CCalculator
	virtual void Thread();
So, when I use the pure virtual function that each CCalculator child overloads - exactly the same code that worked in case one stops working. Thread() contains the same code in both CContainer and CCalculator_GPU.
Failure occurs when trying to cudaFree device memory or cudaUnbindTexture. It seems like something wrong with cuda thread contexts - but I have no ideas what exactly.
Any advice is appreciated.
