Two XWayland issues with 565
I have two issues to report, and this is what they look like:
1st issue:
I’m running FL Studio on Wine on wayland using xwayland, since the wayland driver for Wine is still not finished and it defaults to xwayland, and as you can see the mouse cursor doesen’t get locked into the knob position that I’m tweaking, this works correctly with driver 550, but now the mouse cursor jumps as you can see in the video, and if I recall correctly this issue was introduced with either 555 or 560
2nd issue:
I’m actually including two issues in this point, the first one is that when I launch FL Studio there are some black lines around the logo, in the 560 driver there were alot more and now it’s more difficult to notice but they’re still there and the underlying issue is still present, and those black lines around the logo started appearing after a 550 driver update, on older versions of the 550 driver the black lines weren’t present
and the second issue that you can see in the next video is that when I want to drag a file in the playlist from the browser that has got a longer name than the width of the browser, it won’t let me drag it in, and this issue appeared after the same 550 driver update as mentioned before, as I haven’t had this issue on older releases of the 550 driver.
