TX1 Build DTC error.
git clone git://git.kernel.org/pub/scm/utils/dtc/dtc.git
Cloning into ‘dtc’…
fatal: unable to connect to git.kernel.org:
git.kernel.org[0: 199.204.44.194]: errno=Timeout
git.kernel.org[1: 198.145.20.140]: errno=Timeout
git.kernel.org[2: 149.20.4.72]: errno=Timeout
git.kernel.org[3: 2001:4f8:1:10:0:1991:8:25]: errno=Can’t Access nerwork
git.kernel.org[4: 2620:3:c000:a:0:1991:8:25]: errno=Can’t Access nerwork
How to solve this issue??
Hi Sir,
I think that you can use the following command,
git clone https://git.kernel.org/pub/scm/utils/dtc/dtc.git
Thanks poplar.
I use this command so I get the dtc git.
and I run the make command.
root@jhan-linux:/home/jhan/nVidia/document/TX1/Linux_for_Tegra_tx1/sources/dtc# make
CHK version_gen.h
LEX convert-dtsv0-lexer.lex.c
make: flex: did not find the command.
BISON dtc-parser.tab.c
make: bison: did not find the command.
LEX dtc-lexer.lex.c
Do you know the this problem?
I have not verified, but it sounds like the DTC package dependency for flex and bison are not there. Make sure you have flex and bison packages.
