TX1 Carrier board ACOK Net pull down to GND, instead of Power on button ; Any problem ?
TX1 Carrier board ACOK Net pull down to GND, instead of Power on button press ; Any problem ?
Does the TX1 have same boot up sequence ?
ACOK is CHARGER_PRSNTt#, you can take chapter 3.8 of OEM DG as reference to do the related design. Pull ACOK down will generate a same power up sequence as power button press.
