HI everyone!
when i use the jetson TX1 devkit update system.
2pcs TX1 moudle have the same error number. what’s the meaning?
it looks like different RCM version.
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0000 ] Generating RCM messages
[ 0.0338 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 --download rcm nvtboot_recovery.bin 0 0
[ 0.0412 ] RCM 0 is saved as rcm_0.rcm
[ 0.0717 ] RCM 1 is saved as rcm_1.rcm
[ 0.0766 ] List of rcm files are saved in rcm_list.xml
[ 0.0772 ]
[ 0.0773 ] Signing RCM messages
[ 0.1035 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.1123 ] Assuming zero filled SBK key
[ 0.1280 ]
[ 0.1282 ] Copying signature to RCM mesages
[ 0.1300 ] tegrarcm --chip 0x21 --updatesig rcm_list_signed.xml
[ 0.1407 ]
[ 0.1408 ] Parsing partition layout
[ 0.1819 ] tegraparser --pt flash.xml.tmp
[ 0.1922 ]
[ 0.1923 ] Creating list of images to be signed
[ 0.1953 ] tegrahost --chip 0x21 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.2851 ]
[ 0.2857 ] Generating signatures
[ 0.2907 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.2957 ] Assuming zero filled SBK key
[ 0.3677 ]
[ 0.3679 ] Generating br-bct
[ 0.3991 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.cfg --chip 0x21
[ 0.4062 ] Copying Sdram info from 1 to 2 set
[ 0.4444 ] Copying Sdram info from 2 to 3 set
[ 0.4467 ]
[ 0.4469 ] Updating boot device parameters
[ 0.4490 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatedevparam flash.xml.bin
[ 0.4511 ] Warning: No sdram params
[ 0.4597 ]
[ 0.4599 ] Updating bl info
[ 0.4620 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.4766 ]
[ 0.4766 ] Updating secondary storage information into bct
[ 0.4824 ] tegraparser --pt flash.xml.bin --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 0.4920 ]
[ 0.4921 ] Updating board information from board config into bct
[ 0.4936 ] tegraparser --boardconfig board_config_p2597-devkit.xml --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 0.5001 ]
[ 0.5002 ] Updating Odmdata
[ 0.5016 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatefields Odmdata =0x84000
[ 0.5028 ] Warning: No sdram params
[ 0.5111 ]
[ 0.5112 ] Get Signed section bct
[ 0.5151 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --listbct bct_list.xml
[ 0.5241 ]
[ 0.5242 ] Signing BCT
[ 0.5265 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.5278 ] Assuming zero filled SBK key
[ 0.5361 ]
[ 0.5362 ] Updating BCT with signature
[ 0.5376 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatesig bct_list_signed.xml
[ 0.5485 ]
[ 0.5488 ] Copying signatures
[ 0.5523 ] tegrahost --chip 0x21 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.5536 ] Run tegrabct to update tboot signature in bct
[ 0.5642 ]
[ 0.5643 ] Updating BFS information
[ 0.5656 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatebfsinfo flash.xml.bin
[ 0.5723 ]
[ 0.5724 ] Boot Rom communication
[ 0.5737 ] tegrarcm --chip 0x21 --rcm rcm_list_signed.xml
[ 0.5750 ] BR_CID: 0x621010016440b708140000000c058080
[ 0.5819 ] RCM version 0X13
[ 0.5860 ] Boot Rom communication failed
[ 0.5923 ]
Error: Return value 3
Command tegrarcm --chip 0x21 --rcm rcm_list_signed.xml
version 1.0.0
[ 0.0014 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 --download rcm nvtboot_recovery.bin 0 0
[ 0.0028 ] RCM 0 is saved as rcm_0.rcm
[ 0.0041 ] RCM 1 is saved as rcm_1.rcm
[ 0.0050 ] List of rcm files are saved in rcm_list.xml
[ 0.0182 ]
[ 0.0183 ] Signing RCM messages
[ 0.0229 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0252 ] Assuming zero filled SBK key
[ 0.0378 ]
[ 0.0379 ] Copying signature to RCM mesages
[ 0.0392 ] tegrarcm --chip 0x21 --updatesig rcm_list_signed.xml
[ 0.0458 ]
[ 0.0459 ] Parsing partition layout
[ 0.0473 ] tegraparser --pt flash.xml.tmp
[ 0.0605 ]
[ 0.0605 ] Creating list of images to be signed
[ 0.0660 ] tegrahost --chip 0x21 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.0824 ]
[ 0.0825 ] Generating signatures
[ 0.0838 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.0851 ] Assuming zero filled SBK key
[ 0.1536 ]
[ 0.1538 ] Generating br-bct
[ 0.1554 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.cfg --chip 0x21
[ 0.1615 ] Copying Sdram info from 1 to 2 set
[ 0.1674 ] Copying Sdram info from 2 to 3 set
[ 0.1688 ]
[ 0.1688 ] Updating boot device parameters
[ 0.1702 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatedevparam flash.xml.bin
[ 0.1715 ] Warning: No sdram params
[ 0.1772 ]
[ 0.1774 ] Updating bl info
[ 0.1787 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.1918 ]
[ 0.1919 ] Updating secondary storage information into bct
[ 0.1963 ] tegraparser --pt flash.xml.bin --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 0.2052 ]
[ 0.2054 ] Updating board information from board config into bct
[ 0.2067 ] tegraparser --boardconfig board_config_p2597-devkit.xml --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 0.2133 ]
[ 0.2134 ] Updating Odmdata
[ 0.2146 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatefields Odmdata =0x84000
[ 0.2159 ] Warning: No sdram params
[ 0.2204 ]
[ 0.2205 ] Get Signed section bct
[ 0.2218 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --listbct bct_list.xml
[ 0.2383 ]
[ 0.2385 ] Signing BCT
[ 0.2422 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.2462 ] Assuming zero filled SBK key
[ 0.2534 ]
[ 0.2534 ] Updating BCT with signature
[ 0.2547 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatesig bct_list_signed.xml
[ 0.2614 ]
[ 0.2616 ] Copying signatures
[ 0.2629 ] tegrahost --chip 0x21 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.2641 ] Run tegrabct to update tboot signature in bct
[ 0.2858 ]
[ 0.2860 ] Updating BFS information
[ 0.2894 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatebfsinfo flash.xml.bin
[ 0.2975 ]
[ 0.2976 ] Boot Rom communication
[ 0.2989 ] tegrarcm --chip 0x21 --rcm rcm_list_signed.xml
[ 0.3001 ] BR_CID: 0x621010016440b7422400000010060100
[ 0.3022 ] RCM version 0X13
[ 0.3046 ] Boot Rom communication failed
[ 0.3189 ]
successful
version 1.0.0
[ 0.0013 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 --download rcm nvtboot_recovery.bin 0 0
[ 0.0026 ] RCM 0 is saved as rcm_0.rcm
[ 0.0042 ] RCM 1 is saved as rcm_1.rcm
[ 0.0052 ] List of rcm files are saved in rcm_list.xml
[ 0.0118 ]
[ 0.0119 ] Signing RCM messages
[ 0.0132 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0144 ] Assuming zero filled SBK key
[ 0.0358 ]
[ 0.0360 ] Copying signature to RCM mesages
[ 0.0373 ] tegrarcm --chip 0x21 --updatesig rcm_list_signed.xml
[ 0.0476 ]
[ 0.0477 ] Parsing partition layout
[ 0.0490 ] tegraparser --pt flash.xml.tmp
[ 0.0602 ]
[ 0.0602 ] Creating list of images to be signed
[ 0.0636 ] tegrahost --chip 0x21 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.0760 ]
[ 0.0761 ] Generating signatures
[ 0.0774 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.0785 ] Assuming zero filled SBK key
[ 0.1514 ]
[ 0.1516 ] Generating br-bct
[ 0.1537 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.cfg --chip 0x21
[ 0.1558 ] Copying Sdram info from 1 to 2 set
[ 0.1594 ] Copying Sdram info from 2 to 3 set
[ 0.1684 ]
[ 0.1685 ] Updating boot device parameters
[ 0.1703 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatedevparam flash.xml.bin
[ 0.1733 ] Warning: No sdram params
[ 0.1835 ]
[ 0.1836 ] Updating bl info
[ 0.1867 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.1963 ]
[ 0.1964 ] Updating secondary storage information into bct
[ 0.1976 ] tegraparser --pt flash.xml.bin --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 0.2043 ]
[ 0.2044 ] Updating board information from board config into bct
[ 0.2056 ] tegraparser --boardconfig board_config_p2597-devkit.xml --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 0.2124 ]
[ 0.2125 ] Updating Odmdata
[ 0.2137 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatefields Odmdata =0x84000
[ 0.2236 ] Warning: No sdram params
[ 0.2364 ]
[ 0.2365 ] Get Signed section bct
[ 0.2377 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --listbct bct_list.xml
[ 0.2469 ]
[ 0.2477 ] Signing BCT
[ 0.2596 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.2614 ] Assuming zero filled SBK key
[ 0.2685 ]
[ 0.2686 ] Updating BCT with signature
[ 0.2702 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatesig bct_list_signed.xml
[ 0.2786 ]
[ 0.2791 ] Copying signatures
[ 0.2805 ] tegrahost --chip 0x21 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.2820 ] Run tegrabct to update tboot signature in bct
[ 0.3006 ]
[ 0.3007 ] Updating BFS information
[ 0.3021 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatebfsinfo flash.xml.bin
[ 0.3086 ]
[ 0.3087 ] Boot Rom communication
[ 0.3100 ] tegrarcm --chip 0x21 --rcm rcm_list_signed.xml
[ 0.3112 ] BR_CID: 0x32101001641057492400000013000540
[ 0.3131 ] RCM version 0X210001
[ 0.3169 ] Boot Rom communication completed
[ 1.3596 ]
[ 1.3601 ] Sending BCTs
[ 1.3849 ] tegrarcm --download bct P2180_A00_LP4_DSC_204Mhz.bct
[ 1.3985 ] Applet version 00.01.0000
[ 1.4624 ] Sending bct
[ 1.4627 ] [................................................] 100%
[ 1.6757 ]
[ 1.6759 ] Sending bootloader and pre-requisite binaries
[ 1.6796 ] tegrarcm --download ebt cboot.bin 0 0 --download rp1 tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb 0
[ 1.6817 ] Applet version 00.01.0000
[ 1.7396 ] Sending ebt
[ 1.7425 ] [................................................] 100%
[ 1.9154 ] Sending rp1
[ 1.9527 ] [................................................] 100%
[ 2.1575 ]
[ 2.1576 ] Retrieving storage infomation
[ 2.1686 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 2.1781 ] Applet version 00.01.0000
[ 2.2352 ] Saved platform info in storage_info.bin
[ 2.3732 ]
[ 2.3815 ] tegrarcm --boot recovery
[ 2.3876 ] Applet version 00.01.0000
[ 2.5022 ]
[ 2.5025 ] Flashing the device
[ 2.5086 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
