TX1 debug uart output always Garbled
Hi:
I want to watch the debug uart console output, that’s uart0 on TX1.
On TX1 carrier board, I make wiring as following:
J21 Header Pin 8( UART TXD) ----> Cable RXD
J21 Header Pin 10( UART TXD)----> Cable TXD
J21 Header Pin 9( GND)----> Cable GND
and plug USB connector into host machine, while the cable is MOXA UPort 1150,
Serial debugging assistant is set as 115200n8,
But the console output was always garbled as following:
憲搼9575%7I’=!ee57縮!麐潡_=51e=55繚77=''縲-=-'
縌=9/eR!51靠a!e垮E縔=洓檷!e=eU=5!e7縖eo咫!浚棝摑e59!559/e5!
!憰洀!#55%7I滶靠繎57’垮Re#櫃檷汦
-!#縔’-95eRrR枡靠ai靠蒊煁繜熷=57’-95縐5e#7縔5-!#縔5%9嬁y’557
憴憰=‘-=5%7I滶R57棔摕廍Y’-95=A=9%!#%靠y!%’
IE縖5=9/57=e15縔’-95e臌嫞摍摑
摍彌晽Ee=3%7I滶1e=
-#1縦#5縔5e#咫
=‘-57
薦=e-#1縦!e#=‘e=5#ee=
3潫摃E晨5%97I滶3=95
57縶e=-’‘5縲5-95縔!eeE縔5繖靠ai靠蒊E縔y_Ue{e=-’’
繚憴5縔R麐咫憶摑E
}潔暆岴-95-7I滶R#-#1繘揈靠
-95=5e5#=5%!#縮msae熆-e繚潤咫可IE摀搼彈#-#1嬁51e95=洕5#-‘5smsaR麐
洐彌崜Ee55-#1%7I滶5e#-#1縠%!e
嬁-#13333-ee!晳煙熆
=/!9?-#1%55#7繐彎晽e5#1’1#e-55%]=繒沬刊e!#-39煙潩!3縢Seタ3333
!e#?7%55#7ee!1e5縢梂#1#e=e
e憫晸5##5%7I濢煁煙5#-#1梂cm5縤5-‘7縲!9)55縦=#
枡靠ai靠蒊E縢-5#-#1#煙嫙澘i5e#5’縔!9)5e#7嬁%%
9崙摍崫咫[!!%7I滶5!#57’%9;5%ュR’-95弽櫁E
R枡靠ai靠蒊E縴e5=57’-9#!755%5
'-95e耄崣暉晬
彎憲晬E
5%7I滶嬁g-5#-#5e
!755咫
Ry!%=彎摀E
縞=3刊%%
5eRrR枡靠ai-‘5E縢--/!#俊77==9’縴縜-’-
R_-5煗縀縖!!3
棈棔575%7I;')#57葵煁煙媠-'5縔-9/
eRrR枡靠ai靠!9e!#57縲5;1縮-'煈潖5%e5%7I
彄憲洓5%-5%7I!e5#57-%5Эe5=1-#1’5縮-'R%e暉E
%靠ai靠蒊E縠!#洓嵖emO縠5#
]5575?5%﹠UwmW咯Yu
g彂暉彥me}咯5%7I滶a[咯Ye57縦YMYSmc縔5e-e_咯gm{y[M_WYuWU_
靠蒊E縔=e57縦!e#='縔5e-椏℡uyyae_咯
{g縜i靠ugsUWmY=eeaw骏m!#縖R鹻縤5e桬
’5縔
E嬁w5
57e
Is there something wrong with my settings or anythings else go wrong?
would anyone help me out this?
Thank you very much!
Maybe the problem is related to flow control.
Since you only have RX/TX lines, you should use SW or no flow control. HW flow control wouldn’t work.
Check also speed and parity: serial port should frame 115200 8 N 1
Very often (not always) garbled output is from mismatched speed. Sometimes it is from the cable being long or low quality (adding the CTS/RTS lines and using this for flow control can greatly improve data quality in cases where data is marginal). What is your physical cabling description, and are there any other modifications to the Jetson?
You’ve probably seen these already, but just in case, here is a listing of info on serial console:
[url]http://elinux.org/Jetson/TX1_Serial_Console[/url] (uses CTS/DTS)
[url]http://www.jetsonhacks.com/2015/12/01/serial-console-nvidia-jetson-tx1/[/url] (no CTS/DTS)
