Are there any of the shelf accessories, SOM’s, connectors, or displays to connect to the display connector (J23) on the TX1?
ideally, I’d like to have an adapter with a mating connector to J23, that will convert to LVDS.
Hi Ali_B,
Are you looking for the mating connector of J23?
J23 is Samtec QSH-060-01-H-D-A and the mating connector is a Samtec QTH-060-01-H-D-A.
J23 includes below interfaces:
DSI 2 x4
eDP
eDP HPD
eDP AUX
LCD BL EN/PWM
LCD EN/TE/BIAS EN
SPI0, SPI2
I2C_GP1
Touch INT/RST/CLK
Display control
Hi Trumany!
Thank you so much for your response! Are there any off the shelve SOMs like the current included camera module that I could purchase from anywhere?
I am just assuming if J23 is referenced as display connector, I am assuming that there is currently a display out there that attaches to J23 that I could purchase.
Thank you!
Hi, could you please also provide the interfaces for J22? Much appreciated!
J22 connector is Samtec QSH-060-01-H-D-A and the mating connector is a Samtec QTH-060-01-H-D-A, same as J23.
Interfaces as below, you can find this info in carrier board specification doc in download center.
http://developer.nvidia.com/embedded/dlc/jetson-tx1-developer-kit-carrier-board-spec
CSI up to 6x2 lane
CAM_I2C, Clock & Control GPIOs for the Cameras
Digital Microphone IF
I2S
SPI
I2C
UART
