Hi i flashed with latest new JetPack and it works :)
Thanks for your support and helping me each time…
Not to revive a dead horse but sadly I have this issue and am on 23.2… Same issue. Hangs at boot if monitor is plugged in with following:
[ 5.181940] tsec tsec: initialized
[ 5.184678] tsec tsecb: initialized
[ 5.189189] nvdec nvdec: initialized
[ 5.194174] falcon vic03: initialized
[ 5.197600] falcon msenc: initialized
[ 5.200939] falcon nvjpg: initialized
[ 5.204659] tegradc tegradc.1: Display dc.54240000 registered with id=0
[ 5.209873] display board info: id 0x0, fab 0x0
[ 5.214768] panel_select fail by _node_status
[ 5.218626] display board info: id 0x0, fab 0x0
[ 5.223382] panel_select fail by _node_status
[ 5.227406] parse_tmds_config: No tmds-config node
[ 5.232316] of_dc_parse_platform_data: could not find vrr-settings node
[ 5.238752] of_dc_parse_platform_data: could not find SD settings node
[ 5.245381] of_dc_parse_platform_data: could not find cmu node
[ 5.251060] of_dc_parse_platform_data: could not find cmu node for adobeRGB
[ 5.258022] tegradc tegradc.1: DT parsed successfully
[ 5.264195] display board info: id 0x0, fab 0x0
[ 5.267839] panel_select fail by _node_status
[ 5.272216] gpio wake53 for gpio=225
[ 5.288941] V_REF_TO_SYNC >= 1; H_REF_TO_SYNC < 0
[ 5.291486] tegradc tegradc.1: Display timing doesn't meet restrictions.
[ 5.299369] tegradc tegradc.1: probed
The monitor is a Philips Brilliance 170S, connected via HDMI → DVI adapter → Dual link DVI Cable → Monitor.
If the monitor is unplugged at boot the same section goes as follows:
[ 5.171739] tsec tsec: initialized
[ 5.174444] tsec tsecb: initialized
[ 5.179014] nvdec nvdec: initialized
[ 5.184016] falcon vic03: initialized
[ 5.187459] falcon msenc: initialized
[ 5.190760] falcon nvjpg: initialized
[ 5.194516] tegradc tegradc.1: Display dc.54240000 registered with id=0
[ 5.199720] display board info: id 0x0, fab 0x0
[ 5.204557] panel_select fail by _node_status
[ 5.208467] display board info: id 0x0, fab 0x0
[ 5.213252] panel_select fail by _node_status
[ 5.217249] parse_tmds_config: No tmds-config node
[ 5.222160] of_dc_parse_platform_data: could not find vrr-settings node
[ 5.228594] of_dc_parse_platform_data: could not find SD settings node
[ 5.235227] of_dc_parse_platform_data: could not find cmu node
[ 5.240921] of_dc_parse_platform_data: could not find cmu node for adobeRGB
[ 5.247848] tegradc tegradc.1: DT parsed successfully
[ 5.254069] display board info: id 0x0, fab 0x0
[ 5.257681] panel_select fail by _node_status
[ 5.262055] gpio wake53 for gpio=225
[ 5.266760] tegradc tegradc.1: probed
[ 5.273469] Console: switching to colour frame buffer device 80x30
[ 5.282843] tegradc tegradc.1: fb registered
Then once I reach the logon screen (potentially earlier, haven’t tried), I plug in the screen. dmesg shows:
[ 144.007201] tegradc tegradc.1: hdmi: plugged
[ 144.043491] tegradc tegradc.1: blank - powerdown
[ 144.120041] tegradc tegradc.1: blank - powerdown
[ 144.120349] tegradc tegradc.1: unblank
[ 144.122971] tegradc tegradc.1: nominal-pclk:25200000 parent:25200000 div:1.0 pclk:25200000 24948000~27468000
[ 144.474033] tegradc tegradc.1: unblank
[ 144.492666] tegradc tegradc.1: first frame flipped [158960377]us
And I get VGA on screen. Running a script to change resolution results in full resolution and the following dmesg:
[ 183.698279] HDA: No HDMI device connected
[ 183.699695] sdhci: ================== REGISTER DUMP (mmc1)==================
[ 183.706739] sdhci: Sys addr[0x000]: 0x00000000 | Version[0x0fe]: 0x00000303
[ 183.713782] sdhci: Blk size[0x004]: 0x00007080 | Blk cnt[0x006]: 0x00000000
[ 183.720824] sdhci: Argument[0x008]: 0x12003e00 | Trn mode[0x00c]: 0x00000000
[ 183.727862] sdhci: Present[0x024]: 0x01fb00f0 | Host ctl[0x028]: 0x00000013
[ 183.734900] sdhci: Power[0x029]: 0x0000000d | Blk gap[0x02a]: 0x00000000
[ 183.741941] sdhci: Wake-up[0x02b]: 0x00000000 | Clock[0x02c]: 0x00000007
[ 183.748978] sdhci: Timeout[0x02e]: 0x0000000e | Int stat[0x030]: 0x00000000
[ 183.756012] sdhci: Int enab[0x034]: 0x02ff000b | Sig enab[0x038]: 0x02fc000b
[ 183.763047] sdhci: AC12 err[0x03c]: 0x00000000 | Slot int[0x0fc]: 0x00000000
[ 183.770083] sdhci: Caps[0x040]: 0x376cd08c | Caps_1[0x044]: 0x10006f73
[ 183.777119] sdhci: Cmd[0x00e]: 0x0000341a | Max curr[0x048]: 0x00000000
[ 183.784153] sdhci: Host ctl2[0x03e]: 0x0000300b
[ 183.788674] sdhci: ADMA Err[0x054]: 0x00000000 | ADMA Ptr[0x058]: 0xe9500010
[ 183.795718] mmc1: tuning_window[0]: 0x0
[ 183.795727] mmc1: tuning_window[1]: 0x0
[ 183.795733] mmc1: tuning_window[2]: 0x0
[ 183.795739] mmc1: tuning_window[3]: 0x0
[ 183.795745] mmc1: tuning_window[4]: 0x0
[ 183.795752] mmc1: tuning_window[5]: 0x0
[ 183.795758] mmc1: tuning_window[6]: 0x0
[ 183.795765] mmc1: tuning_window[7]: 0x0
[ 183.795770] sdhci: Tap value: 46 | Trim value: 8
[ 183.795774] sdhci: SDMMC Interrupt status: 0x00040000
[ 183.795777] sdhci: =========================================================
[ 183.802817] mmc1: Command CRC error, intmask: 60001 Interface clock = 204000000Hz
[ 185.074039] EXT4-fs (mmcblk0p1): recovery complete
[ 185.074606] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 194.115776] tegradc tegradc.1: blank - powerdown
[ 194.164211] tegradc tegradc.1: unblank
[ 194.188068] tegradc tegradc.1: nominal-pclk:107964480 parent:107964258 div:1.0 pclk:107964258 106884756~117681196
[ 194.539146] tegradc tegradc.1: unblank
Pretty sure the EXT4-fs comments are not related.
Thoughts? It is frustrating having to always unplug the monitor…
First, see if the nVidia-specific files are in place:
sha1sum -c /etc/nv_tegra_release
If that passes, install packages “read-edid” and “edid-decode”. After you’ve unplugged and re-plugged…whatever is needed to get the display connected without the system failing…check this:
get-edid | parse-edid
get-edid | edid-decode
Hi linux dev .actually I am receiving no response when I connected the Jetson tx1 to my hdmi supported tv screen .
I am using my LG tv as a monitor for the Jetson tx1.what can I do in order to see the Jetson booting up and see the linux desktop .?
By far the easiest way to find out what is going wrong is via the serial console. See this for information:
http://elinux.org/Jetson/TX1_Serial_Console
If the video is the only thing wrong, then the alternate access would be via ssh. Can you ssh in?
If there is some means of access, does this file exist?
/sys/kernel/debug/tegradc.1/edid
If it does exist, what is the output of its content:
cat /sys/kernel/debug/tegradc.1/edid
It sounds like your cabling is pure HDMI with no adapters…can you verify if this is correct?
