TX1 module could not support 1080P resolution IP camera and 30 frames per second
Currently, I am working on getting the video frames from the camera to TX1 through MIPI interface, and we faced some challenges, as the write speed of the FLASH in TX1 is lower than what we expected.
We are using a video camera with Full HD (1080p) 30FPS writing into the FLASH of TX1, however, the TX1 FLASH seems to only accept 40Mbits/second according to our measurement, which is lower.
I will like to verify if this is a TX1 limitation? If it is not, how to solve this challenge.
Best,
Yingyu
hello yingyux,
could you please share your commands that writing the video file.
also, had you try to enhance the tegra performance by running jetson_clock.sh
thanks
