TX1 OpenSceneGraph Build
Anyone can point me to where the headers and libraries files are located for tegraX1?
I want to build Openscenegraph but failed to find the location of the following path:
OPENGL_INCLUDE_DIR
OPENGL_EGL_LIBRARY
OPENGL_gl_LIBRARY
I realize the pre-installed filesystem has libEGL.so and libGLESv2.so.2 in /usr/lib/arm-Linux-gnueabihf/tegra-egl but it is not found in the sample file system.
In addition, I do not know where should I find the header files for OPENGL.
Is there any guide that I can follow or has anyone managed to build openscenegraph on Jetson TX1?
If you post the download location for your exact version of OpenSceneGraph it might be possible for someone to test compile it and post results.
OpneSceneGraph-3.2.3 from http://www.openscenegraph.org/index.php/download-section/stable-releases
I was wondering where can I locate the necessary Tegra OpenGL files so as to begin building.
