I’ve designed a base board for the TX1 and I want to modify the pinmux. So I did the following
- Downloaded the pinmux spreadsheet from the download page
- Modified the pins (with no errors)
- Created dtsi files
- Exported the CSV file of my pinmux spreadsheet
- Cloned the pinmux tools from https://github.com/NVIDIA/tegra-pinmux-scripts
- Modified 'csv-to-board.py' to define my board
- Generated my board file then my u-boot header file
Now I have my header file for u-boot, I did all the stuff to build a custom board in u-boot (basing it off of p2371-2180) and when I attempt to build u-boot it reports an error with the generated header file:
In file included from /Linux_for_Tegra/sources/u-boot_source/board/nvidia//.c:14:0:
/Linux_for_Tegra/sources/u-boot_source/board/nvidia//pinmux-config-.h:20:11: warning: implicit declaration of function ‘TEGRA_GPIO’ [-Wimplicit-function-declaration]
The ‘TEGRA_GPIO’ is referenced in the generated header file, while the file .c which is a copy of /Linux_for_Tegra/sources/u-boot_source/board/nvidia/p2371-2180/p2371-2180.c Doesn’t recognize that define. I was contemplating raising an issue on the pinmux tool github page but this seems to be a disagreement between the u-boot source file and the pinmux tool. So either one or both need to change.
I worked around it by making my include file look like the previous include file so I’m not blocked but wanted to bring this up.
Dave
