I am new to this community and CUDA overall, so far I am having a good time diving in.
I do have a question for you, maybe you know the answer.
I would mainly like to do power and clock profiling on the Jetson TX1 DevKit.
I’ve tried to do so using the option on the Visual Profiler tool but it doesn’t seem to work for me.
To measure the power, the easiest is to plug the devkit into a Kill-a-Watt device or similar. But that is less accurate and includes the AC/DC converter loss in the power brick that you wouldn’t necessarily encounter when powering from battery for example. Alternatively you could use a DC bench supply with digital ammeter and power the devkit directly off DC, or use a multi-meter or device like this: http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=17864
I was thinking more about a detailed breakdown.
I thought that the power subsystem indicated in the image link below could be accessed somehow for power sensing.
Those INA’s are not yet supported in the software. After production release of the individual module, they may or may not be enabled. The nvidia-smi / NVML has not historically been implemented on Tegra platforms.
I have just found the products supported in the NVML API Reference Guide which I didn’t notice before.
I’ll leave a link here, maybe someone else is also looking for this feature.
