Regarding Temperature Cycling - JESD22-A104D , we have some question as below please help to check :
• What profiles they used from Table 1, Table 2, Table 3, Table 4
• The total duration of the test (which will likely be based on above)
Hi Abby_Su,
Regarding Temperature Cycling. we did the test by referring the newer version of the standard than JESD22-A104D, which has profile for -40 °C to 105 °C, 250 cycles.
Do you have the new version document can share to me? Thanks.
Hi! Kay
1.The L4T_Jetson_X1_Developer_Kit_User_Guide has device complies on page 21 , and can we have RoHS report ?
[This device complies with the following directives:
• R&TTE Directive for radio equipment
• Low Voltage Directive for electrical safety
• RoHS Directive for hazardous substances
A copy of the Declaration of Conformity to the essential requirements may be obtained directly from NVIDIA
GmbH (Floessergasse 2, 81369 Munich, Germany).]
1.MSL:□ 1 □ 2 □ 2a □ 3 □ 4 □ 5 □ 5a □ 6
2.Strategic Hi-Tech Commodity(SHTC):□ Yes □ No
3.Green Level:□ GM(RoHS) □ GM(RoHS) and HF □ GP(Sony) □ GP(Sony) and HF
