Hello, I have been having trouble setting up ROS for the TX1 with this kit:
https://developer.nvidia.com/embedded/learn/jet-diy-robotics-kit
when I run
source ~/.bashrc; source ~/catkin_ws/devel/setup.sh; roslaunch jet_bringup jet_real.launch
I get this error:
[ERROR] [1528699343.433569]: Unable to sync with device; possible link problem or link software version mismatch such as hydro rosserial_python with groovy Arduino
Full Output:
... logging to /home/ubuntu/.ros/log/8d43f964-6d42-11e8-b06c-00044b6738e3/roslaunch-tegra-ubuntu-12575.log
Checking log directory for disk usage. This may take awhile.
Press Ctrl-C to interrupt
Done checking log file disk usage. Usage is <1GB.
xacro: Traditional processing is deprecated. Switch to --inorder processing!
To check for compatibility of your document, use option --check-order.
For more infos, see http://wiki.ros.org/xacro#Processing_Order
xacro.py is deprecated; please use xacro instead
started roslaunch server http://10.200.105.195:39642/
SUMMARY
PARAMETERS
* /jet_drive_controller/angular/z/has_acceleration_limits: False
* /jet_drive_controller/angular/z/has_velocity_limits: False
* /jet_drive_controller/base_frame_id: base_link
* /jet_drive_controller/cmd_vel_timeout: 1.0
* /jet_drive_controller/enable_odom_tf: True
* /jet_drive_controller/left_wheel: left_wheel_joint
* /jet_drive_controller/linear/x/has_acceleration_limits: False
* /jet_drive_controller/linear/x/has_velocity_limits: False
* /jet_drive_controller/pose_covariance_diagonal: [1e-05, 1e-05, 10...
* /jet_drive_controller/publish_rate: 100
* /jet_drive_controller/right_wheel: right_wheel_joint
* /jet_drive_controller/twist_covariance_diagonal: [0.0, 0.0, 0.0, 0...
* /jet_drive_controller/type: diff_drive_contro...
* /jet_drive_controller/wheel_radius: 0.077
* /jet_drive_controller/wheel_radius_multiplier: 1.0
* /jet_drive_controller/wheel_separation: 0.36
* /jet_drive_controller/wheel_separation_multiplier: 1.0
* /joint_state_controller/publish_rate: 50
* /joint_state_controller/type: joint_state_contr...
* /joy_node/autorepeat_rate: 20
* /joy_node/deadzone: 0.3
* /joy_node/dev: /dev/input/js0
* /robot_description: <?xml version="1....
* /rosapi/params_glob: [*]
* /rosapi/services_glob: [*]
* /rosapi/topics_glob: [*]
* /rosbridge_websocket/address:
* /rosbridge_websocket/authenticate: False
* /rosbridge_websocket/bson_only_mode: False
* /rosbridge_websocket/delay_between_messages: 0
* /rosbridge_websocket/fragment_timeout: 600
* /rosbridge_websocket/max_message_size: None
* /rosbridge_websocket/params_glob: [*]
* /rosbridge_websocket/port: 9090
* /rosbridge_websocket/retry_startup_delay: 5
* /rosbridge_websocket/services_glob: [*]
* /rosbridge_websocket/topics_glob: [*]
* /rosbridge_websocket/unregister_timeout: 10
* /rosdistro: kinetic
* /rosversion: 1.12.13
* /serial_node/baud: 115200
* /serial_node/port: /dev/ttyACM0
* /teleop_twist_joy/axis_angular: 4
* /teleop_twist_joy/axis_linear: 5
* /teleop_twist_joy/scale_angular: 1
* /teleop_twist_joy/scale_linear: 1
* /usb_cam/camera_frame_id: usb_cam
* /usb_cam/image_height: 240
* /usb_cam/image_width: 320
* /usb_cam/io_method: mmap
* /usb_cam/pixel_format: yuyv
* /usb_cam/video_device: /dev/video1
NODES
cmdvelrelay (topic_tools/relay)
controller_spawner (controller_manager/spawner)
jet_driver_node (jet_driver/jet_driver_node)
joy_node (joy/joy_node)
odomrelay (topic_tools/relay)
robot_state_publisher (robot_state_publisher/robot_state_publisher)
rosapi (rosapi/rosapi_node)
rosbridge_websocket (rosbridge_server/rosbridge_websocket)
serial_node (rosserial_python/serial_node.py)
teleop_twist_joy (teleop_twist_joy/teleop_node)
usb_cam (usb_cam/usb_cam_node)
auto-starting new master
process[master]: started with pid [12588]
ROS_MASTER_URI=http://10.200.105.195:11311
setting /run_id to 8d43f964-6d42-11e8-b06c-00044b6738e3
process[rosout-1]: started with pid [12601]
started core service [/rosout]
process[rosbridge_websocket-2]: started with pid [12618]
process[rosapi-3]: started with pid [12619]
process[serial_node-4]: started with pid [12620]
process[joy_node-5]: started with pid [12621]
process[teleop_twist_joy-6]: started with pid [12622]
process[usb_cam-7]: started with pid [12624]
process[controller_spawner-8]: started with pid [12635]
process[robot_state_publisher-9]: started with pid [12644]
process[cmdvelrelay-10]: started with pid [12650]
process[odomrelay-11]: started with pid [12653]
process[jet_driver_node-12]: started with pid [12655]
[ERROR] [1528699326.101000877]: Couldn't open joystick /dev/input/js0. Will retry every second.
[ INFO] [1528699326.159774728]: velocity multiplier: 10.000000
registered capabilities (classes):
- rosbridge_library.capabilities.call_service.CallService
- rosbridge_library.capabilities.advertise.Advertise
- rosbridge_library.capabilities.publish.Publish
- rosbridge_library.capabilities.subscribe.Subscribe
- <class 'rosbridge_library.capabilities.defragmentation.Defragment'>
- rosbridge_library.capabilities.advertise_service.AdvertiseService
- rosbridge_library.capabilities.service_response.ServiceResponse
- rosbridge_library.capabilities.unadvertise_service.UnadvertiseService
[ INFO] [1528699326.314381215]: using default calibration URL
[ INFO] [1528699326.314605012]: camera calibration URL: file:///home/ubuntu/.ros/camera_info/head_camera.yaml
[ INFO] [1528699326.314734331]: Unable to open camera calibration file [/home/ubuntu/.ros/camera_info/head_camera.yaml]
[ WARN] [1528699326.314789434]: Camera calibration file /home/ubuntu/.ros/camera_info/head_camera.yaml not found.
[ INFO] [1528699326.314889952]: Starting 'head_camera' (/dev/video1) at 320x240 via mmap (yuyv) at 30 FPS
[INFO] [1528699326.391895]: Controller Spawner: Waiting for service controller_manager/load_controller
[INFO] [1528699326.396982]: Controller Spawner: Waiting for service controller_manager/switch_controller
[INFO] [1528699326.401629]: Controller Spawner: Waiting for service controller_manager/unload_controller
[INFO] [1528699326.405661]: Loading controller: jet_drive_controller
[ INFO] [1528699326.425809648]: Controller state will be published at 100Hz.
[ INFO] [1528699326.431966261]: Wheel separation will be multiplied by 1.
[ INFO] [1528699326.436829625]: Left wheel radius will be multiplied by 1.
[ INFO] [1528699326.436918268]: Right wheel radius will be multiplied by 1.
[ INFO] [1528699326.439194824]: Velocity rolling window size of 10.
[ INFO] [1528699326.443069516]: Velocity commands will be considered old if they are older than 1s.
[ INFO] [1528699326.445152952]: Allow mutiple cmd_vel publishers is enabled
[ INFO] [1528699326.449440029]: Base frame_id set to base_link
[ INFO] [1528699326.451265399]: Odometry frame_id set to odom
[ INFO] [1528699326.455106446]: Publishing to tf is enabled
[ INFO] [1528699326.501753161]: Odometry params : wheel separation 0.36, left wheel radius 0.077, right wheel radius 0.077
[ INFO] [1528699326.509993418]: Adding left wheel with joint name: left_wheel_joint and right wheel with joint name: right_wheel_joint
[ WARN] [1528699326.548523676]: updateConfig() called on a dynamic_reconfigure::Server that provides its own mutex. This can lead to deadlocks if updateConfig() is called during an update. Providing a mutex to the constructor is highly recommended in this case. Please forward this message to the node author.
[ INFO] [1528699326.559528497]: Dynamic Reconfigure:
DynamicParams:
Odometry parameters:
left wheel radius: 1
right wheel radius: 1
wheel separation: 1
Publication parameters:
Publish executed velocity command: 0
Publication rate: 100
Publish frame odom on tf: 1
[INFO] [1528699326.575270]: Loading controller: joint_state_controller
[ERROR] [1528699326.582050625]: Could not load controller 'joint_state_controller' because controller type 'joint_state_controller/JointStateController' does not exist.
[ERROR] [1528699326.582133019]: Use 'rosservice call controller_manager/list_controller_types' to get the available types
[ WARN] [1528699326.664365016]: unknown control 'focus_auto'
[INFO] [1528699326.923410]: Rosbridge WebSocket server started on port 9090
[ERROR] [1528699327.584324]: Failed to load joint_state_controller
[INFO] [1528699327.585210]: Controller Spawner: Loaded controllers: jet_drive_controller
[INFO] [1528699327.605870]: Started controllers: jet_drive_controller
I get this error no matter what I roslaunch.
I am certain I setup my ips in both /etc/hosts and ~/.bashrc correctly.
I’m at a loss, help would be much appreciated!
Additional Question: Will running roslaunch execute my code onto the robot?
